Ductless Mini-Split Systems A/C
Postby Ken A Hood » Mon May 29, 2006 10:35 am
Anyone have any info on these? I've seen them around, and it looks like it's a 2-piece system; an outside condensing unit and the indoor fan coil and built in heat pump.
Specs:
heat mode
cooling mode
dehumidification mode
fan mode
Capacity Heating @ 47F [BTU/h] 10300
Capacity Heating @ 17F [BTU/h] 5600
HSPF 7.2
SEER 10.5
EER 9.8
COP 3.1
Moisture Removal [Pts/h] 2.3
Air Flow [CFM] @ High|Med|Low 450/360/282
Sound Rating Indoor db (A) 40
Sound Rating Outdoor db (A) 51
Operating Range - Cooling [F] 0 to 115
Operating Range - Heating [F] 17 to 75
ELECTRICAL DATA
Cooling Watts | Amps 950 / 8
Heating Watts | Amps 950 / 8
Max TD Fuse/Breaker [A] 20
REFRIGERANT LINES
Connections Flare
Liquid Line OD [Inch] 1/4
Suction Line OD [Inch] 3/8
Max Line Length [Ft] 49
Max Height Difference [Ft] 26
DIMENSIONS
INDOOR SECTION
WxHxD [Inch] 32x11x7
Weight [Lbs] 28
OUTDOOR SECTION
WxHxD [Inch] 32x20x8
Weight [Lbs] 79
Ken A Hood
Images: 42
Postby SteveH » Mon May 29, 2006 11:54 am
Looks like a great unit for a teardrop. Who builds it and how much is it? What type of refrigerant does it use? I'm sure it would have to be evacuated and charged after installation?
OK, did a search and found all are too big in capacity (9000 btu up) and too expensive for my budget...$800 up.
SteveH
SteveH
Images: 42
Postby Ken A Hood » Mon May 29, 2006 12:33 pm
It uses R410A Refrigerant; I have the link saved at home. I'll post it later tonight.
Ken A Hood
Images: 42
Postby Ken A Hood » Wed Jul 26, 2006 4:26 pm
Found another one, it's a TOYO ductless mini split air conditioner and the current bid is under $30.00 (Shipping is $150.00 to Canada and the US)
LINK
Ken A Hood
Images: 42
Postby ALAN GEDDES » Wed Jul 26, 2006 4:43 pm
10K btu and over 100 pounds. No thanks.
Alan
ALAN GEDDES
Images: 34
Postby Ken A Hood » Wed Jul 26, 2006 4:54 pm
17.8 lbs (indoor fan)
66.6 lbs (exterior compressor)
84.4 lbs total
Anyway, just putting it out there since others are always looking for other options.........
Ken A Hood
Images: 42
Postby ALAN GEDDES » Wed Jul 26, 2006 6:10 pm
28 and 79 is what it says in specs.
Alan
ALAN GEDDES
Images: 34
Postby Ken A Hood » Wed Jul 26, 2006 6:52 pm
"Brand new 3/4HP (7000BTU) TOYO Digital DC Inverter ductless mini split air conditioner" is what the ad says;
Model #TA-07CS 3/4hp 7000BTU
17.8 LB(interior) 64.4 LB(exterior) =82.2 LB
Ken A Hood
Images: 42
Re: Ductless Mini-Split Systems A/C
Postby dms2871 » Wed Jan 27, 2016 7:32 am
Ken A Hood wrote:Anyone have any info on these? I've seen them around, and it looks like it's a 2-piece system; an outside condensing unit and the indoor fan coil and built in heat pump.
Specs:
heat mode
cooling mode
fan mode
HSPF 7.2
SEER 10.5
EER 9.8
COP 3.1
ELECTRICAL DATA
REFRIGERANT LINES
Connections Flare
DIMENSIONS
INDOOR SECTION
Weight [Lbs] 28
OUTDOOR SECTION
Weight [Lbs] 79
Have anyone done this I thought of this too
dms2871
Postby lrrowe » Wed Jan 27, 2016 8:56 am
A quick search in this forum of "ductless mini ac" produced these results. I believe there are more out there also.
search.php?keywords=Ductless+mini+ac
Bob
lrrowe
Images: 439
Postby Colemancooler » Wed Jan 27, 2016 5:30 pm
I have installed these, in my opinion they are too big for a teardrop, they require most are 120vac and use the power wires to communicate from the indoor unit to the outdoor unit. Installation is very easy. They are very "over engineered" have no electric heat like a standard heat pump, but instead don't run the indoor fan during defrost. I would stick to a known manufacturer. Because parts are very specific from manufacturer to manufacturer, and a lack of parts availability would turn a simple repair into an equipment replacement
Colemancooler
Postby MtnDon » Wed Jan 27, 2016 5:49 pm
Like many things we want to fit into TD's almost everything is too large, has too much capacity, etc. Same thing with a mini-split. OTTCT uses one in his CTC, but he is huge compared to a TD. I love mini-splits; they are very efficient and some can run "backwards" and provide very efficient heating too. Much better than electric resistance heating, depending on the exterior temperature and the unit design. Some of the better ones can be programmed to run at reduced speed which = reduced capacity and would be good for TD's and CTC's. If you use one that is too big and can not be slowed down you have the same problems as with any oversized A/C; too much on - off cycling and too little moisture removal. They are huge dollars compared to window shakers.
MtnDon
Images: 24
Postby dms2871 » Sat Jan 30, 2016 1:41 am
Colemancooler wrote:I have installed these, in my opinion they are too big for a teardrop, they require most are 120vac and use the power wires to communicate from the indoor unit to the outdoor unit. Installation is very easy. They are very "over engineered" have no electric heat like a standard heat pump, but instead don't run the indoor fan during defrost. I would stick to a known manufacturer. Because parts are very specific from manufacturer to manufacturer, and a lack of parts availability would turn a simple repair into an equipment replacement
I have installed these too but not into a td, the one im looking at has inverter technology heats cools dehumidifies also they have all the replacement parts also for some reason it breaks down
dms2871
Postby dms2871 » Sat Jan 30, 2016 1:49 am
MtnDon wrote:Like many things we want to fit into TD's almost everything is too large, has too much capacity, etc. Same thing with a mini-split. OTTCT uses one in his CTC, but he is huge compared to a TD. I love mini-splits; they are very efficient and some can run "backwards" and provide very efficient heating too. Much better than electric resistance heating, depending on the exterior temperature and the unit design. Some of the better ones can be programmed to run at reduced speed which = reduced capacity and would be good for TD's and CTC's. If you use one that is too big and can not be slowed down you have the same problems as with any oversized A/C; too much on - off cycling and too little moisture removal. They are huge dollars compared to window shakers.
Product Description:
Innova Inverter Ductless Mini-Split A/C systems are ultra-quite, energy efficient, and compact in size compared to most of the systems offered in the market today. The ease of installation makes it perfect for any home or business. The system offers heating, cooling, dehumidifier, and fan function. (1) Year Limited Parts Warranty Included. Inverter technology allows the system to vary the compressor speed instead of constantly turning off and on, which consumes the most power. This technology helps the system to the room in a constant comfortable temperature without wasting power. Innova includes all necessary parts and accessories to complete your entire installation. The package includes: - Indoor Unit and Outdoor Unit (Condenser) - Indoor Unit Hanging Bracket - Remote Control + Remote Control Holder - 4.9m Line Set/Control Cable/Drain Hose - (2) Line Set Wraps, Line Set Sleeve, Sleeve Cap, Neoprene - Installation Manual - Remote Control Manual - User Manual - (1) Year Limited Parts Warranty Included
dms2871
Postby Shadow Catcher » Sun Jan 31, 2016 7:41 pm
All of the systems I see here are expensive and too big for a tear, this can be done for less than $200 and less than 50# easily replaceable.
80999
Images: 200
