Spare Tire Size
Spare Tire Size
Postby Thunder3 » Sat Jul 25, 2020 1:40 pm
I'm running 15" wheels on my tear and has a matching spare on the tongue. It's really big and heavy and I would like to move the spare under the frame but it won't fit between the rails. I don't want to mount it on the side wall either or carry in the TV. Could I use a 13" or 14" as a spare in a pinch and not hurt anything? Same lug pattern of course. Thoughts?
Thunder3
Re: Spare Tire Size
Postby tony.latham » Sat Jul 25, 2020 4:19 pm
I've thought about finding a "doughnut" spare at the junkyard and using it on my 4.5-5 hubs...
I see no reason you couldn't use a smaller tire.
Re: Spare Tire Size
Postby PCO6 » Sun Jul 26, 2020 5:38 am
Thunder3 wrote:I'm running 15" wheels on my tear and has a matching spare on the tongue. It's really big and heavy and I would like to move the spare under the frame but it won't fit between the rails. I don't want to mount it on the side wall either or carry in the TV. Could I use a 13" or 14" as a spare in a pinch and not hurt anything? Same lug pattern of course. Thoughts?
I have 15" Jeep wheels on my trailer and use a mini spare from an old Jeep Cherokee. I fabricated a swing down mount for it under the tongue. I installed it on my trailer axle simply to test it but I have never had to use it.
PCO6
Re: Spare Tire Size
Postby bartek » Tue Mar 23, 2021 4:00 pm
How big is your Jeep mini spare? I have similar problem to Thunder3 and was worried that 13inch spare would be quite a bit smaller than 15 inch wheels, resulting either in a scary tilt of the trailer and/or undue stress on the axles...
I even considered carrying two 13" spares (I happen to have them, so the only downside would be additional weight) - flats don't happen often, so I suppose having to change both wouldn't be that much of a pain...
Image 6x10 family teardrop, build thread: http://www.tnttt.com/viewtopic.php?f=50&t=73426
bartek
Images: 84
Re: Spare Tire Size
Postby TimC » Tue Mar 23, 2021 5:05 pm
I'm of the opinion that if I suffer a flat on the road I will swap my flat 175/80R13 for a 4.80-12 spare and limp to the next town to get a replacement or repair. Not an apples to apples comparison of 15" to a 13" spare but close enough.
If you are a person that will be inconvenienced with slowing down and want to continue at speed and fix the flat when convenient go with an identical spare.
Tim
Niagara, WI
TimC
Images: 736
Re: Spare Tire Size
Postby bartek » Tue Mar 23, 2021 5:31 pm
Yeah, that's my thinking as well - definitely looking for something good enough to just get to the next town, I just don't know how much I can push the size difference and still be able to drive for a short distance, even if at 30-40mph
bartek
Images: 84
Re: Spare Tire Size
Postby TimC » Tue Mar 23, 2021 6:38 pm
bartek wrote:Yeah, that's my thinking as well - definitely looking for something good enough to just get to the next town, I just don't know how much I can push the size difference and still be able to drive for a short distance, even if at 30-40mph
That's the $64,000 question. Probably worth a test by mounting one on the trailer and see how it tows. Better to test when you have time than hundreds of miles from home. Full disclosure - I have never tested my theory.
Tim
Niagara, WI
TimC
Images: 736
Re: Spare Tire Size
Postby gudmund » Tue Mar 23, 2021 9:15 pm
Camp Inn sells their trailer's with a "donut" spare and say they work fine = enough to get you down the road so as to get the flat tire repaired.
gudmund
Images: 39
Re: Spare Tire Size
Postby Cary Winch » Wed Mar 24, 2021 8:10 am
Camp-Inn does not use a donut spare. It is a fully rated Load range C trailer wheel/tire. It has no speed, distance or load restrictions on it like a donut. It is just a bit smaller and much narrower and looks rather silly on there, so you would want to get the flat tire fixed quickly before too many people see it. Camp-Inn uses this wheel/tire combo in the same stowage manner as a donut in a car. Having a spare tire well under the mattress is a great way to carry a spare, but a full sized spare tire for most teardrops typically would never fit in a under floor location like that.
There is nothing wrong with the idea of using a donut spare on a teardrop camper, it is a nice space saving idea actually. Trailers have the ability though to use skinny off the shelf trailer wheel/tire combos for spare tires which is what we do. These will fit in a space similar to a donut. The advantage is being able to continue on the trip without the donut restrictions listed above.
Cary
Cary Winch
Teardrop Manufacturer
Re: Spare Tire Size
Postby gudmund » Wed Mar 24, 2021 10:15 am
Camp Inn, I stand corrected - it's been a 'long' while since reading your trailer paperwork here on the internet, but -thank you- for also making the point I was trying to convey here about the use of a smaller tire in size and how it could still work as a spare tire in the time of need..........take care
gudmund
Images: 39
Re: Spare Tire Size
Postby exminnesotaboy » Fri Mar 26, 2021 5:43 pm
If you have a 5x4.5 lug pattern, some full size fords in the late 90’s had a donut spare with an aluminum rim. I pulled one from a 99? Crown Victoria at a junk yard. It was never used, in great shape, matched my existing tire profile height and was only 10$. It was MUCH lighter than a steel rim and fit really well up under my teardrop frame. I believe these aluminum spares were some crown vics, mustangs and Lincoln town cars in the late 90’s. Might be worth a check of your local junkyard.
exminnesotaboy
Re: Spare Tire Size
Postby tony.latham » Fri Mar 26, 2021 6:15 pm
exminnesotaboy wrote:If you have a 5x4.5 lug pattern, some full size fords in the late 90’s had a donut spare with an aluminum rim. I pulled one from a 99? Crown Victoria at a junk yard. It was never used, in great shape, matched my existing tire profile height and was only 10$. It was MUCH lighter than a steel rim and fit really well up under my teardrop frame. I believe these aluminum spares were some crown vics, mustangs and Lincoln town cars in the late 90’s. Might be worth a check of your local junkyard.
I take it the rim fit over your axle hub protrusion?
https://www.ebay.com/itm/273859201219?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=273859201219&targetid=1068323853830&device=c&mktype=pla&googleloc=9029516&poi=&campaignid=12594560362&mkgroupid=120171157815&rlsatarget=pla-1068323853830&abcId=9300522&merchantid=7850444&gclid=Cj0KCQjwjPaCBhDkARIsAISZN7RiCIzJxdvKHyA7t8dFQliueIkdOHp0Ts7o8x3ztkpVvBi2d5T-3mkaAor8EALw_wcB
Re: Spare Tire Size
Postby exminnesotaboy » Sat Mar 27, 2021 9:41 am
It did on mine(3500lb torsion axle with orig hubs) as I test fit it when I picked it up. Note: I am not sure that eBay posting you listed is for the lighter aluminum rim - it looks like it may be steel. Most eBay posting list them as aluminum if they are aluminum. I know I had to dig through a lot of junkyard late 90’s Ford/Lincoln trunks to find the one that didn’t attract a magnet.
exminnesotaboy
Re: Spare Tire Size
Postby tony.latham » Sun Mar 28, 2021 7:30 am
Im sure you’re right. I posted that to show the hole in the rim.
Re: Spare Tire Size
Postby ebis » Tue Apr 06, 2021 10:19 pm
Please check the date code of your spare tire. Not sure that I would trust a 22 year old tire even if it is in great shape. Anyways $10 for
aluminum rim is a good deal.
ebis
