Hello from CO!
Hello from CO!
Postby amorrison96 » Mon Jan 10, 2022 8:10 pm
Hi everyone,
I'm in the early stages of building my first teardrop trailer using Tony Latham's book as a guide. It's a 5x8 design I came up with; I'm happy to hear what others have to say about it.
Sleeping area for 2 adults, reading & interior lights. Kitchen galley: IceCo freezer/cooler; sink (water pump, 7 gal fresh/gray water); coleman camping stove.
I designed the trailer as well; 2" square tubing (1/8 walls), Timbren axle-less spindles/wheels (14"); I expect the deck height to be at 17".
I'm debating on solar; our camping trips are typically at developed campsites where there is power, but as the kids get older we may want to do more dispersed camping. Then again, by then I may want to build another one altogether...
I started my build two weeks ago; I built a stand for it and made the floor using two 1/4 sheets of sanded plywood with 1x6 framing in between, and insulation in the cavities. Next up is to seal the underside - epoxy, Henry's, or "The Mix" (?) which appears to be multiple coats of a changing paint thinner & polyurethane blend.
I'll post photos once I can shrink them.
amorrison96
Re: Hello from CO!
Postby tony.latham » Mon Jan 10, 2022 8:49 pm
And back at ya...
You know, there's a reason folks sealed the bottom of their teardrops with a tar product in 1940... but products have gotten a lot better.... just my two-bits on the subject. The mix will soak in and really seal it up.
Holler if you have any questions. :thumbsup:
Re: Hello from CO!
Postby amorrison96 » Wed Jan 12, 2022 5:52 pm
@Tony: You recommend epoxy for underside of floor, right?
amorrison96
Re: Hello from CO!
Postby tony.latham » Wed Jan 12, 2022 6:44 pm
amorrison96 wrote:@Tony: You recommend epoxy for underside of floor, right?
I do. It soaks into the wood and plasticizes it. But the mix will do fine. Both soak in. Surface finishes, such as Henry's or paint can lift. Henry's works... but it takes a long time to dry and is messy.
Re: Hello from CO!
Postby timhill28 » Tue Feb 15, 2022 2:31 am
Enjoy the build! Welcome
timhill28
Re: Hello from CO!
Postby rjgimp » Tue Feb 15, 2022 2:02 pm
So are the 1x6 boards on end in your floor framing? That’s quite a floor with 6 inches of insulation!
-Rob
rjgimp
Images: 7
Re: Hello from CO!
Postby amorrison96 » Tue Feb 15, 2022 2:55 pm
rjgimp wrote:So are the 1x6 boards on end in your floor framing? That’s quite a floor with 6 inches of insulation!
That would be quite the floor; probably reach an R30 rating!
But no, 1x6's are laying flat, using 3/4 insulation board in the cavities. Wood is about R1, 3/4" board is around R4; not a huge difference, but it's something.
amorrison96
Re: Hello from CO!
Postby tony.latham » Tue Feb 15, 2022 3:49 pm
I think he's following my book.
