water proofing your wood
Re: water proofing your wood
Postby QueticoBill » Sat Mar 04, 2017 2:53 pm
Well - lots of differences. I can find spar for $35/gallon and mineral spirits for $10, an I'll use both regularly for a number of other projects. It may be I have a half gallon of spar - enough to soak all the ply. And I'm trying for $1000 total so $40 is more significant. Plus I have all the tools I need and it seems not to easy to clean tools - brushes and rollers - for epoxy. And the health hazards of or conversely the personal protection necessary for epoxy seem greater than those for spar varnish. All that and if clear coat, you likely need spar or some uv inhibitor on top of the epoxy.
I just suggested it isn't fear of epoxy that stops many people from using it.
QB
QueticoBill
Images: 22
Postby tony.latham » Sat Mar 04, 2017 4:07 pm
rruff wrote:
tony.latham wrote:Raka's Six-Quart kit is $100
US Composites is even cheaper. If you buy 6.6 gal you can get it down to $44/gal + shipping. http://www.shopmaninc.com/epoxy.html
:thumbsup: I just bookmarked that.
Postby tony.latham » Sat Mar 04, 2017 4:12 pm
QueticoBill wrote:Well - lots of differences. I can find spar for $35/gallon and mineral spirits for $10, an I'll use both regularly for a number of other projects. It may be I have a half gallon of spar - enough to soak all the ply. And I'm trying for $1000 total so $40 is more significant. Plus I have all the tools I need and it seems not to easy to clean tools - brushes and rollers - for epoxy. And the health hazards of or conversely the personal protection necessary for epoxy seem greater than those for spar varnish. All that and if clear coat, you likely need spar or some uv inhibitor on top of the epoxy.
Bill:
I've been using epoxies for forty years and protect myself with nitrile gloves.
I'm glad you and everyone else on this forum builds as an individual and each follow their own compass. This would be a dull place to chat about our trailers if they were all the same.
I look forward to seeing your build finished and photos of it's maiden voyage. :thumbsup:
Postby rruff » Sun Mar 05, 2017 1:01 am
tony.latham wrote: :thumbsup: I just bookmarked that.
I'm toying with the idea of a hand laid FG outer skin kinda like KCStudly is doing on his. I want a beefier layer of FG than he is using though (his is 2x 6oz cloth). A layer of 1708 and a layer of 10oz cloth looks pretty good, and weight and cost is nearly identical to 3mm Okoume marine ply + 6oz cloth.
rruff
Postby rruff » Sun Mar 05, 2017 9:22 pm
Stumbled on another company. Unbeatable single gallon price of $58 (2 gal is $100) and free shipping. http://www.ebay.com/itm/CLEAR-EPOXY-RES ... Sw2gxYsJeK
rruff
Postby rruff » Mon Apr 24, 2017 10:57 pm
Finally settled on E Bond epoxy in Ft Lauderdale. No website, you have to call. Resin is $26/gal, 1289 (slow) hardener is $30/gal, 2-1 ratio. Shipping is ~$12/gal so <$40/gal shipped. I've made a couple samples and it seems to work fine. It's thinner than the other cheap epoxies I've used which is good for wet out.
rruff
Postby dancam » Sat Aug 12, 2017 6:34 pm
Just read through this thread and my first question was asked but not answered- what's your wait time between coats? or do you just keep rolling it on non-stop? Seems that with 4 different mixture ratios you would have different coats. So do you keep rolling on the 75/25 miture till it wont soak up any more and then wait for that to flash off before doing the 50/50 and so on? And if coating 1/8th plywood do you do both sides at the same time or do one side and let it dry, then do the other side so all the solvents can evaporate?
Second- for paint adhesion it looks like no one is sanding it, but is the satin, semi gloss or gloss urethane best for paint to adhere to later?
Third- flooring urethane was mentioned. All the floor urethane I have seen is interior, is that what was used?
Thanks
dancam
Postby tony.latham » Sat Aug 12, 2017 7:08 pm
I keep applying it until it either won't take anymore or until I arbitrarily call it good. I sometimes put a coat of uncut poly on the next day to really seal it.
Postby dancam » Sun Aug 13, 2017 12:52 pm
tony.latham wrote:I keep applying it until it either won't take anymore or until I arbitrarily call it good. I sometimes put a coat of uncut poly on the next day to really seal it.
Ok, so you just roll on the 75% mineral spirits, 25% urethane untill its soaked, then one coat undiluted the next day?
Or do you start with a different mixture?
dancam
Postby lthomas987 » Sun Aug 13, 2017 6:42 pm
Yes. No different mix to start.
Laura
lthomas987
Images: 204
Postby tony.latham » Sun Aug 13, 2017 7:55 pm
That's what I do. But I'm not Doctor Mix. :frightened: That's only on high use surfaces like the counter.
Postby dancam » Tue Aug 29, 2017 10:47 am
So i made a huge mistake on my tongue box. Had everything test fitted great, took it apart, spread the glue on, my wife handed me the piece back and we glued it on upsidedown.... i dont think i can take it apart to redo without wrecking the whole thing. No idea how we didnt notice. This piece is rotary mohogany because its wider than 5ft and i didnt want to do it in 2 pieces with baltic birch. So far my experience with the rotart mohogany is that the rough back layer is not attached to the core as well, splits, splinters and delaminates way easier than the good side.
So my question is will 'the mix' fix that? I know it wont make it smoother, but will it prevent the splintering and delamination? This top should see no rocks hitting it from the wheels.
Here are 2 photos of it and the urethane i bought. It was $45/gal instead of $75 for the name brand stuff. Anyone used it before?
Thanks!
dancam
Postby tony.latham » Tue Aug 29, 2017 11:31 am
That's one sweet looking box. But it sure don't look boxy.
I'll be interested in seeing it on your camper.
Postby dancam » Wed Aug 30, 2017 4:35 pm
tony.latham wrote:That's one sweet looking box. But it sure don't look boxy.
I cant wait to see it on there either. Tonight or to.orrow i will bring it home and test fit it.
dancam
Postby dancam » Wed Aug 30, 2017 10:13 pm
Well its on :/ photos are here: http://tnttt.com/viewtopic.php?t=66816
dancam
