rruff wrote:tony.latham wrote:Raka's Six-Quart kit is $100
US Composites is even cheaper. If you buy 6.6 gal you can get it down to $44/gal + shipping. http://www.shopmaninc.com/epoxy.html
QueticoBill wrote:Well - lots of differences. I can find spar for $35/gallon and mineral spirits for $10, an I'll use both regularly for a number of other projects. It may be I have a half gallon of spar - enough to soak all the ply. And I'm trying for $1000 total so $40 is more significant. Plus I have all the tools I need and it seems not to easy to clean tools - brushes and rollers - for epoxy. And the health hazards of or conversely the personal protection necessary for epoxy seem greater than those for spar varnish. All that and if clear coat, you likely need spar or some uv inhibitor on top of the epoxy.
I just suggested it isn't fear of epoxy that stops many people from using it.
tony.latham wrote: I just bookmarked that.
tony.latham wrote:I keep applying it until it either won't take anymore or until I arbitrarily call it good. I sometimes put a coat of uncut poly on the next day to really seal it.
dancam wrote:tony.latham wrote:I keep applying it until it either won't take anymore or until I arbitrarily call it good. I sometimes put a coat of uncut poly on the next day to really seal it.
Ok, so you just roll on the 75% mineral spirits, 25% urethane untill its soaked, then one coat undiluted the next day?
Or do you start with a different mixture?
tony.latham wrote:then one coat undiluted the next day?
That's what I do. But I'm not Doctor Mix. That's only on high use surfaces like the counter.
tony.latham wrote:That's one sweet looking box. But it sure don't look boxy.
I'll be interested in seeing it on your camper.
Users browsing this forum: Bing [Bot] and 13 guests
