Rockhopper - Solutions!
Re: Rockhopper - starting electrical...
Postby mikeschn » Sun Sep 23, 2012 12:26 pm
I thought I'd work on the doors today...
So I grabbed my windows and other hardware, and a piece of scrap... and mocked up a door.
Uh, that doesn't look right. The window got pushed forward because of the door latch, and it got pushed down because of the top hinge. :oops:
I think we're gonna need different windows... Lets's see...
What if we made them 12x18? I know Grant has some of those... Lets see how that might look...
That works better! :D
But we'll have to work on those doors another weekend...
Images: 479
Re: Rockhopper - drawers done!
Postby mikeschn » Sun Sep 30, 2012 3:46 pm
I worked on the drawers yesterday AND today. What a lot of work. I can't remember them being THAT much work. And I didn't even use dovetails. :?
But the drawers make the space much more usable and accessible. I'm glad I went this route!
Images: 479
Postby bdosborn » Sun Sep 30, 2012 5:27 pm
Nice drawers. What kind of latch will you use to keep them closed in transit?
Images: 777
Postby RAYVILLIAN » Mon Oct 01, 2012 6:31 am
The drawers look good Mike. Remember our discussion on how long it would take you to finish this trailer? Well I think I under estimated your busy schedule. :lol:
Gary
111961Image
RAYVILLIAN
Images: 109
Postby pete42 » Fri Oct 12, 2012 7:59 am
Mike I have been kinda following along with out saying anything
I will restate what I have said before I am amazed how great everone does when building their own trailers,
just when I thought "they can't improve on that" someone, like you does.
for what it's worth Scamp trailers spray epoxy on their floors they have a big spray booth they just spray resin all over the floor nice and water tight.
When I built my all fiberglass airplane, a Burt Rutan designed VariEze when laying the fiberglass onto the foam we used 1" brushes and "stippled" the resin onto the 'glass.
since we were building an airplane we wanted to keep it as light as possible once the 'glass is wetted anymore resin added to the 'glass only adds weight not strength so we used squggies to remove the excess resin.
I like the way you solve problems on your great looking trailer, this window doesn't look right lets try another, the lines don't look right lets cut off 6"
the back wall is to narrow lets build it wider.
you make me tired just reading about the things you do and redo reminds me of that other Mike, Mike Holmes "make-it-right".
pete
pete42
Postby Ned B » Sat Feb 02, 2013 12:58 pm
so, Mike... any update? :lurk:
Ned B
Postby Ron Dickey » Sat Feb 02, 2013 10:39 pm
Gives us all lots of ideas :thumbsup:
I did wonder and maybe I missed it but how did the front window go in?
You have come a long way over the years Mike!!
Ron Dickey
121377......134179
Ron Dickey
Images: 711
Postby mikeschn » Sun Mar 03, 2013 5:14 pm
Okay, so winter is almost over... 3 weeks until spring!!! I figured I'd better get off my duff and start moving again.
Today's project was to get the 2nd door started. Can you believe it took all day just to frame out this silly door? :?
FWIW, I did use biscuits through and through!!! ;)
But any sawdust is better than no sawdust at all! :)
Images: 479
Re: Rockhopper - 2nd door started...
Postby starleen2 » Sun Mar 03, 2013 7:45 pm
Much better layout on the door - the new window cut out looks promising. :thumbsup:
starleen2
5th Teardrop Club
Postby stomperxj » Sun Mar 03, 2013 11:31 pm
Looks good Mike- I see you are using the trusty Stanley Gate Hinge. Those are the best hinges for the price I think...
stomperxj
Postby Martiangod » Mon Mar 04, 2013 9:55 am
Much better look on the door, bravo
Now git it done,
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby mikeschn » Sun May 26, 2013 6:52 am
Summer is finally here again!
Got the doors done, and got the outside skin on.
I put putty in all the holes, and this morning I am going to start sanding...
The plan is to be able to start putting fiberglass on the roof this afternoon.
Images: 479
Re: Rockhopper - Outside skinned
Postby Oldragbaggers » Sun May 26, 2013 8:36 am
I hope you have a great day for it!! Your build looks real good.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby mikeschn » Sun May 26, 2013 9:03 am
Becky,
Do you need a special primer to go over the fiberglass resin before you can paint?
Images: 479
Postby Oldragbaggers » Sun May 26, 2013 11:08 pm
I use the Pre-Kote primer that is recommended for use with the Interlux Brightsides paint. However, I just read a post by Doug Hodder (I think) that said it is not necessary. I trust his knowledge. I'm almost anal about following directions though, so if the paint can says I need to prime, I prime.
Becky
Oldragbaggers
Images: 331
Users browsing this forum: No registered users and 24 guests
