by Wolffarmer » Mon Nov 25, 2013 11:29 pm
Did you take a gander at the other 2 lanterns he has for sale now? Total fakery. The brass that he says is probably is a 220B is not and any one who has dipped a toe into the vintage Colemans can easily spot that. The pump cap is a pressed steel cap with 2 screws. Those appeared in the 220D series. Until then the pump was a screw in cap. So easy to spot. Plus all the BRASS !!!!!! And the lantern he calls a "Military kerosene burner" is made up of a MilSpec fount. Top of something else, probably an E model as they are common and cheap and pre heater cup added. Both fakes and miss represented. Call those 2 lanterns frauds.
Randy
