homemade coleman lantern case
Postby lancew » Wed Nov 28, 2012 6:17 pm
Just curious if any of you coleman users ever made your own case. if so, what did you use and how did you make it. i tired of breaking those high cost glass globes. i have one that is cracked top to bottom but i refuse to buy a new one. i have been pondering about using a 5 gallon bucket and spray foam. before i do this, i thought i would go out of my comfort and ask folks here. thank you for any input.
lancew
Re: homemade coleman lantern case
Postby campmaster-k » Wed Nov 28, 2012 7:12 pm
I have seen it all on here. From super nice museum quality boxes (Doug) to a cut off cardboard tube used for cement work. Even just a cardboard box works really good. Your idea of the foam in a bucket would work, big foot print however.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby lancew » Wed Nov 28, 2012 8:44 pm
big foot print ? im assuming carbon, if so. i will hold my thought on that comment lol
lancew
Postby wagondude » Wed Nov 28, 2012 8:54 pm
I think he was talking about the amount of space the bucket would take up. Get some ridgid foam (the pink or blue stuff) and build a box just the size you need. Cover it with paint and canvas (check the Foamie section for more details). You should be able to get the foam as construction scraps. If you dont have an old canvas drop cloth laying around, an old sheet would work just as well. Or your spray foam idea inside a cardboard box and the box could be waterproofed with a 50/50 mix of mineral spirits and polyurethane (or just paint and cloth). Lots of ways to do it. Best to make it take the least amount of space that you can.
Bill
101137
wagondude
Images: 35
Postby campmaster-k » Thu Nov 29, 2012 1:10 pm
Good Idea bill. :thumbsup:
-Kirk
Build thread -
campmaster-k
Postby doug hodder » Sat Dec 01, 2012 12:04 am
I've found that if you build a box so that the sides are protected and the bottom of the lantern is captured with wood stops so that it can't move around (felt pads in the bottom), and then put a piece of foam rubber in the top so that when you close it it compresses, it keeps the lantern from moving about in the box. My cases for the 242's are only 7x7x14 and the 220's are 8x8x16. Much smaller than a bucket and stores easier since it's flat sides. I'm not a big fan of the plastic vacuum formed Coleman cases. I've yet to break a globe in one. Just 1/4" ply and some 3/4" material on the corners. I figure if I've got a premium 70+year old lantern...it deserves a nice storage box. Doug
Postby KCStudly » Sun Dec 02, 2012 12:34 am
Very nice work there, Doug. Thanks for sharing. :thumbsup:
Postby lancew » Mon Dec 03, 2012 5:21 pm
Thank you Doug. Those lantern boxes are awesome. i obviously over thought the whole thing. off to the shop to make me couple.
lancew
Postby Woodbutcher » Mon Dec 03, 2012 8:38 pm
Not beautiful but cheap and easy......
Just a concrete form tube cut into 3 pieces with some pink styrofoam for a bottom. Cut a second ring to keep the lantern from moving around. About 3 bucks a piece. Probably not what people thought I would make I bet!
Woodbutcher
Postby KCStudly » Mon Dec 03, 2012 9:43 pm
Very thrifty, Woodbutcher, but I sure would like to see what you could do if you put your mind to it! :thumbsup:
Postby Hillmann » Tue Dec 04, 2012 4:24 pm
doug hodder wrote:
I am pretty sure we need more pictures of your boxes, those are pretty sweet.
Hillmann
Postby jeporter25 » Wed Dec 05, 2012 10:53 pm
This is not exactly home made but here's what i got. I found that a double wide milk crate holds a 425, a can of fuel. and 2 200as. I did add a bottle opener to the outside of it and its pretty prefect for camping.
go box.jpg (83.43 KiB) Viewed 11390 times
jeporter25
Postby PresTx82 » Fri Dec 14, 2012 9:28 pm
I've been away from the forum for awhile and just thought I'd pop my head in again. I'm glad to see that the Coleman Collecting area is very active.
Doug, those cases are excellent. Do you have some pics on the inside? Love to see them.
Mark
El Paso, Texas
PresTx82
Postby doug hodder » Sat Dec 15, 2012 12:21 am
Here's an inside pic. I cut 2 pieces of 1/4" ply in an arc to sort of capture the base, then padded the bottom with some felt. This one is for a 242. I just ripped a piece of 45 degree material to back up the joint. On the first one I did...I did a box joint. Not such a clean thing to do on 1/4" ply...too much tear out on it. I also padded the sides where the vent might contact the sides with felt as well. I just brush painted out the interior with a decent Coleman green paint. Another easy thing to do is to screw in a small binder clip into the lid to hold spare mantles. Piece of foam rubber holds the lantern secure when it closes.
Postby matthewh » Sun Dec 29, 2013 7:09 pm
Woodbutcher, I decided to adopt your concrete tube idea... with one add-on. At Lowes, If you walk over to the plumbing section where they sell the galvanized duct work, you can find the IMPERIAL 8-in Dia Galvanized Cap Fitting (Item #: 31883 | Model #: GVL0111) for $5.25. It fits perfectly (and snugly). Total project about $11.00. I like this inexpensive solution for my old, Sears lantern.
matthewh
