danlott wrote:I also think you could use the mouldings on the bottom of the trailer. They would cover the frame and the moulding flange would bolt to the bottom of the frame. Here are a couple SketchUp ideas that I had. The first one is 8 feet long and the second one is 10 feet long. Also if you do end up making other radius size corners then you could do just about any design you wanted.
Dan
Hardryder56 wrote:Very nice concept and execution. I think that by supplying the corner blocks you have designed people would be able to build trailers of different sizes as they need. If I understand your 60/30 and 37/16 corner block you have simply cut the 12" 90* block to a shorter length?
Hardryder56 wrote:I like the shape of your rear door design and think it would work well as a slide in truck camper for a pick up. I will be following this thread with interest.
rowerwet wrote:if you get one of the teardrop oriented parts suppliers to sell this stuff many of the lurkers around here will end up being builders
not to mention the manufacturing possibilities...
wagondude wrote:Wow! that is a lot of options. If this thing takes off, there will be lots of cool trailers getting built. All of those shown look very good.
rowerwet wrote:unless it is painted, FRP isn't UV stable, Filon is the version of FRP that is stable it seems to be easier to find in areas where RV's are made, expensive to get for the rest of us. If I was building using your awesome corners I would cover the plywood with painted canvas.
Dan
