KCStudly wrote:Are you thinking about which of the holes you will use? I'm thinking that the two widest ones and one of the lower ones would be more than adequate. My thinking is that the extra holes are provided for nailing, whereas you are screwing, which is much stronger.
jseyfert3 wrote:Do you have any thoughts on the post I made just about yours (bottom of page 5), where they guy on the other forum pointed out that wood and steel have different thermal expansion rates? Is that likely to be an issue with how I'm planning to build it?
KCStudly wrote:jseyfert3 wrote:Do you have any thoughts on the post I made just about yours (bottom of page 5), where they guy on the other forum pointed out that wood and steel have different thermal expansion rates? Is that likely to be an issue with how I'm planning to build it?
Yes. My thoughts are that he was correct. He is not an expert, and does not know enough about the subject.
The expansion rate differences are insignificant for the temperature extremes and lengths of material concerned.
The thermal expansion rate for steel is 0.0000073 in/in / deg F.
For wood with the grain it is 0.0000017.
So if we assume you assemble at 65 deg F, and common temperatures in your region or where you camp can range from 100 to zero deg F, then the biggest excursion from 65 deg F is delta 65 deg.
Over 48 inches and 65 deg, the steel will shrink about .023 inch and the wood about .005, for a relative change of .018 inch. If we assume that the action is symmetrical, the screws at either side of your trailer will only see .009 relative change.
Reference expansion rates: http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html
I think the bigger issue with hay wagons is that there is no box structure on top to hold the deck true, so when they overload something that has an axle at each end with hay bales a mile high and drag it over rutted fields it will tend to twist.
Your relatively light single axle trailer with a nice rigid box attached won't have that problem.
KCStudly wrote:2 ft spans are pretty generous, and that is about what I have in my floor (maybe closer to 18 inches?). I only have 3/16 thick skins (5 mm) but have a piece of scrap 1/2 ply on rosin paper laid down during the build so I can walk on it. Once the roof goes on and the mattress is down there won't be so much point loading (will only be crawling or laying down) so it will be fine. The foam is, however, fully glued to both the upper and lower skins, so there is a great deal of modular strength built in. Just stuffing chunks of foam under your floor won't give the same strength as a torsion box.
If you want to dance on it, I wouldn't go less than the 1/2 inch, and with larger spans and a single top skin only, you might want the 5/8. Just an opinion from what I have read here, really; not hard fact. $.02
Mary C wrote:No, put the battery LOW. I cant tell you exactly why, but I saw a batterys damage on a person once (acid) and I would put it low, protected and away from persons.
KCStudly wrote:How about under the floor near the axle? Just ahead or just behind it. Check out how Danny does his in traditional builds. I think Zach's X2 had an under slung battery, as well.
KCStudly wrote:On a street going camper (as opposed to an off road rig) ground clearance is like a triangle; greatest near the axle tapering toward the tongue and rear "bumper" (assuming that nothing pokes up higher than the axle). Near the axle is not affected by dips and transitions.
Here is a link to a thread on under slung battery mounts.
