Mary C wrote:OK take a one by two and put around the door opening. Engineering says the sides go in first. Now make another frame that will fit inside the door frame I screwed mine together in the corners. Now lay it down on top of a two inch foam. Now mark on the inside of the wood frame. Cut the foam out.glue the frame around the foam, next mark for the door handle, cut a square of wood and inlay it into the foam. Use lots of glue.. let dry and cover door in canvas. Make sure you leave at least a half inch between the door and frame before you cover it in canvas. I did not leave enough room for the canvas and glue I am having to sand my doors. If i did it again I would leave more room for the canvas. You can do it! I know it seems difficult but really it was easy. Order your hinges on line, stainless or aluminum. It took four days for delivery.
Mary C.
