Who has used Filon?
Finishes, paints and coatings
Re: Who has used Filon?
Postby bdosborn » Wed Oct 22, 2014 7:25 pm
I vacuum bagged mine but I still rolled it out first.
Images: 777
Postby Atomic77 » Wed Oct 22, 2014 8:13 pm
I think I'm going to use West epoxy on the walls then vacuum bond them. Any ideas on the ceiling?
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby bdosborn » Wed Oct 22, 2014 9:24 pm
I floated the filon on the roof, no cement....
Images: 777
Postby Atomic77 » Wed Oct 22, 2014 9:29 pm
bdosborn wrote:I floated the filon on the roof, no cement....
How does that work exactly?
Michael
The Astroliner
Atomic77
Images: 309
Postby bdosborn » Wed Oct 22, 2014 10:05 pm
You just lay the skin on the trailer roof and use the edge trim to hold it down. No glue required. Most people do it that way without a hitch.
Images: 777
Postby Atomic77 » Thu Oct 23, 2014 9:04 am
bdosborn wrote:You just lay the skin on the trailer roof and use the edge trim to hold it down. No glue required. Most people do it that way without a hitch.
Is this method the standard? Does that still work when the front wall is also part of the roof?
124393124392
Michael
The Astroliner
Atomic77
Images: 309
Postby bdosborn » Thu Oct 23, 2014 7:53 pm
Pretty standard, I don't know anyone who hasn't floated their roof skin. My front wall is part of the roof and I wrapped the filon down to the frame:
Images: 777
Postby Toyotamike » Sat Nov 29, 2014 1:23 am
Mine has oil canned on one side pretty bad over this summer. Anyone manage to salvage the filon when they fixed this issue? I want to fix before I bed liner the whole thing.
Toyotamike
Postby Atomic77 » Sat Nov 29, 2014 5:42 pm
Toyotamike wrote:Mine has oil canned on one side pretty bad over this summer. Anyone manage to salvage the filon when they fixed this issue? I want to fix before I bed liner the whole thing.
How did you bond your Filon to your walls? Were your walls coated with anything prior to the installation? How did you do your roof?
Michael
The Astroliner
Atomic77
Images: 309
Postby Atomic77 » Wed May 06, 2015 8:03 pm
Mike... Did you ever fix this issue?
Michael
The Astroliner
Atomic77
Images: 309
Return to Skinning secrets
