- Screen shot 2014-12-15 at 9.15.48 AM.png (107.14 KiB) Viewed 2406 times
Most of you are not gonna drain the battery at more then 0.5 to 0.2C so the volts stay at 13.3 until 85-95% empty
this is the best because a reg flooded battery drops to 11 volts like a rock.
- Screen shot 2014-12-15 at 9.15.35 AM.png (128.1 KiB) Viewed 2406 times
After 2000 cycles at 80% DOD...the battery still would hold 80% charge for another 2000 cycles,
then it would hold 65% charge for 2,000 more cycles. you would never touch that with a flooded $80 T105 golf cart battery. Hi guys , I say a set of lithium because to get 12 volts , you actually need 4 cells each which is called a 3.2 volt LifeP04 cell. The battery if fully charged would peak out at 14.5 volts. If you remove about 5% it mostly sits at 13.3 volts until you remove about 80% of the voltage or charge. From there it quickly drops to 10 volts , where you need to stop as you are now 90- 95% DOD.
The lithium battery stored for a long time is best at 50% I know a guy who let them sit for 3 years no problem. You would kill your flooded after 6 months for sure.
The weight of the lithium is actually 25% of the flooded as 100 ah lithium is really equal to 200 ah flooded.
The lithium really has zero water maintenance , no gassing, no worries, allows actually 3C power draw, so you can put a 300 amp load on a 100 ah lithium battery. I have been sleeping 6 months with a 1250 ah lithium right under my bed inside the trailer. It charges perfect with my outback 80 from my solar panels. IMHO - it's much harder to kill a lithium then a flooded battery because of the battery management system - BMS , it's sort like using 2 -3 rubbers if you get my drift. - I'll add more details latter today.
Buying Lithium battery is sort of like this - if you buy 50 gallons of gas or less it's $4 a gallon, however if you can buy 400 gal storage tank and gas in one shot then it's only $1 per gallon of gas - but for the next 10 years or 4,000 gallons you get your gas for $1 a gallon as long as it goes into your big tank first !!!
It's really a absolut win, win, win as long as one time you can afford a bigger storage tank.
