Hi Ned,
Good to here from you and that things are happening toward your build. I had seen and replied to your newbie post.
I was talking to Jeff a while ago and he said he knew you.
I assume the molding you are referring to is what I have covering the join between roof and sides. It is unequal angle alloy, we got it from Ullrich Aluminium , part No. UA1093 1.6x25x12x5m. I used it all the way around the roof and the hatch.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3091&image_id=122499)
Click here is their extrusion catalogue
http://www.ullrich.co.nz/pdfs/Brochure_pdfs/ebooks/extrusion/files/index.html I also used UA1731 1.6X20X12X5M around the inner liner on the hatch. This had three uses 1), to protect the edge of the liner, 2), to have a tidy finish along the edge of the liner, 3), to created a drip line for any water that gets in that far and direct it into the channel down the inside of the walls. I also used UA1534 22X10 down the back edges of the walls under where the hatch closes. I put one each side and over lapped them. I wanted to use a U section there but they are all deeper than they are wide and that wouldn't have bent around the curve and would have looked too heavy if it had. They come in 5m lengths and at the time were about $12 - $14 +gst per length.
The channel I used in the galley is UA1410 drip mould 22mm comes in a 4m length.
![Image](https://www.tnttt.com/gallery/image.php?album_id=3091&image_id=122495)
Couldn't find Hurricane hinge in NZ and didn't want to risk damage possibilities of shipping from overseas. I got three big stainless steel hinges from Bunnings, and with the alloy trims have a narrow gap with a foam weather seal. The hatch overlaps the walls down the sides and I have the foam seal down there as well.
Should any water get past there I have a ledge across below the hinges and the drain channels down the sides. We haven't had any issues with water getting in to the galley either camped or on the road.
![122500](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=122500)
![122498](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=122498)
![122494](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=122494)
