Hello! I'm building a *really* small Teardrop for use in my backyard (2' wide by 6' long, no galley). I'm making it primarily from things laying around the shop or wood the carpet place down the street throws out. I'm building in a single door on one side, with a fixed 25" square window from the ReStore opposite. I have some Lexan I was going to use for the door window, but I'm also trying to make sure I have enough ventilation in case I have the door closed, especially since the big window won't open.
I'm thinking an 18" x 24" window in the door (or smaller), and I could add another 8x10 to the "foot" end, but because of my extra small interior space a Wiley window won't work. Will top hinges with some sort of drip channel and/or gasket keep weather out? Anyone ever build a plexiglass sliding window like they use in Deer blinds? I don't have to worry about water tightness at highway speeds (or any speed, really. The "trailer" is 2 pneumatic casters with wheelbarrow style handles on the opposite end).
Would it be better to also add some soffit-style vents to the side, so I don't have to rely on windows to get ventilation? I have a bunch of these, the same that I've seen in some homeless shelter designs, but I don't know how much air will flow through them.
Thanks for any advice you might have!
-Matthew
