Moderator: 2bits
Actually, I replaced those about 20K ago. The one ahead of the cat died on one of my trips to Kaleefoornya, and I replaced both when I got back. It's not too bad a job if the exhaust system is cold.Running at freeway speeds with the front one dead might have used up some of the cat's nine lives.aggie79 wrote:you may want to you may want to check the oxygen sensor(s).
aggie79 wrote:and you usually need to get a special tool/socket.
aggie79 wrote:I once had a VW Passat with a high-perf V-6. It had 4 catalytic converters that needed to be replaced at a cost of $300 each - ouch!
2bits wrote:After the spark plug blew out ...
2bits wrote:Of course you couldn't just buy the converter, you had to buy the converter and the entire exhaust system that bolted to the engine (who designs this stuff??). ... I can't recall how much but it was like a grand or something.
aggie79 wrote:BTW, I've picked up a consulting gig.
capnTelescope wrote:aggie79 wrote:BTW, I've picked up a consulting gig.
Congrats! Now, all you have to do is start lining up the next gig. You're not off the treadmill yet. What line of work are you in, Tom?
aggie79 wrote:I know many wouldn't call it a profession, but I'm a city planner.
starleen2 wrote:Good to hear from you ARKPAT - it's been a long time since we have heard from you - glad you are doing fine We are finally finished with the major snow storms and what is left is melting away. The total for the season was 115 inches! Our plan is to attend Beaver's Bend gathering this April for our semi annual trip down South. Looking forward to seeing our Southern friends!
ARKPAT wrote:Wow
Been a while sence I have posted anything
I'm still alive and still moving ---- just slower
