Our "Spot-Hopper"
Our "Spot-Hopper"
Postby BamaJNJ » Sun Oct 05, 2014 9:18 pm
Hi everyone. Let me start off by saying I am not a preplanning type person, its more of a do as you go type thing and i know it makes for more work(and money) but its what works for me...we are using a Design we seen on a post by Mike Schnieder. it says its a Modified 10ft grasshopper, dunno, looked good to us so we went with it124993
BamaJNJ
Images: 52
The OPT-INN build
Postby BamaJNJ » Sun Oct 05, 2014 9:28 pm
Not being good at remembering to take pictures, we didnt get a good pic of the trailer we are using before we did our modifying to it, so we learned the basics on google sketchup and did a rendering of the trailer frame there 124500 we got this old boat frame for 250.00, not the perfectly ideal trailer but itll work...
BamaJNJ
Images: 52
The OPT-INN build
Postby BamaJNJ » Sun Oct 05, 2014 9:40 pm
124502 building the platform, it is 5'x10', 3/4 ply floor, (3) 2x3 ribs running length wise connected with some 2x2s and 2x3s width wise, had to cut (2) 5'x4' 3/4 ply sections and a 2'x4' 3/4 ply section to cover it of course
BamaJNJ
Images: 52
Re: The OPT-INN build
Postby BamaJNJ » Sun Oct 05, 2014 9:56 pm
125006 bottom side of platform after sealing with fiberglass resin
125007 moved the forward outside rails inward on trailer...later realized needed reinforcement after doing this, also extended trailer 2 ft to rear to make tongue weight not so heavy(hard to see that in pic)
125008 platform just setting on trailer not bolted down yet
BamaJNJ
Images: 52
Postby BamaJNJ » Mon Oct 20, 2014 7:58 pm
125532125531 first pic is a shot of our side profile... 4'x10'6" over all....second pic is a shot of the way we ended up splicing the ply to make our 10 ft sides...tried it using biscuit joiner and biscuits but just seemed to flimsy...we ended up using 5/8 ply which probably played a role in the biscuit joints not working for us( or we didnt do it right ), anywho liquid nails, screws and left over scrap, from creating the wall, worked out
BamaJNJ
Images: 52
Postby BamaJNJ » Thu Jan 29, 2015 5:55 am
Build currently on hold till warmer dryer weather, dont have a shop to keep it in, so she is bundled up nice and tight....come on spring!!
BamaJNJ
Images: 52
Postby BamaJNJ » Mon Jun 01, 2015 5:06 am
132398132397132396132395
here is a little progress over this last weekend, not being any sort of carpenter it has been a learning experience for us both so far
BamaJNJ
Images: 52
Postby BamaJNJ » Mon Jun 29, 2015 7:01 am
133527 test fit the hinge...we found out we cut it wrong..crap :cry:
133529133528 skinned the inside of camper...color looks orangish but its not, golden pecan stain on some underlayment sheets from lowes... we think its oak
133526133530133531
progress on the kitchen cabinets
BamaJNJ
Images: 52
Postby BamaJNJ » Sat Aug 01, 2015 6:56 am
134729a few more pics of our progress, ceiling partially installed!!
134728thought we'd try a mobile DVD player
134727the big opening is our entrance to the electrical race way/small storage area, it will get a door of course
BamaJNJ
Images: 52
Postby BamaJNJ » Sat Aug 01, 2015 6:57 pm
134753
sleeping area cabinets trimmed out!! woohoo!!
BamaJNJ
Images: 52
Postby mikeschn » Sat Aug 01, 2015 6:59 pm
Wow, nice job on your modified Grasshopper so far!!! :thumbsup:
Images: 479
Postby BamaJNJ » Sat Aug 01, 2015 7:03 pm
yes weve learned the hard way about stains and different wood types not staining the same...oh well...itll give it character ;)
BamaJNJ
Images: 52
Postby BamaJNJ » Sat Aug 01, 2015 7:05 pm
Thanks Mike!! :D ...it was an old post you put up in '07 that had the dimensions we used
BamaJNJ
Images: 52
Postby rebapuck » Sun Aug 02, 2015 12:20 am
Looks good.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby BamaJNJ » Tue Aug 11, 2015 6:37 pm
135126
test fit of the hatch door
135125
top view of electrical raceway/storage area between our double bulkhead...plmbrs tape is going to hold blue board foam insl
135124
we finally have POWER!!!
BamaJNJ
Images: 52
Users browsing this forum: No registered users and 23 guests
