Tomterrific wrote:After buying a hurricane hinge because that should be leak proof, it leaks. Stupid me spends about $60 total, has to drill holes in the hinge and then stress out installing the flimsy thing. I feel like I should have bought a cheap piano hinge and covered it with rubber, my first thought. After I read this forum it seemed the better solution would be a hurricane hinge. The dew went right through the hinge as soon as I opened the hatc this morning. The hinge gets water in the joint between the two parts and capillary action pulls the water through. As it is now this hinge is worthless.
Thank you for any solution.
Tom in Columbus
wiseguydirk wrote:For mine I put an Aluminum L bar underneath the top part of the hinge with the top canter levering over the top to prevent direct streams of water from hitting the hinge.. With silicone between the roof aluminum and the top part of the hinge. Looks great and adds more protection. I can provide an image if you want to see.
