It has been a while but that's because I am trying to make some progress and camping season looms. It was blue skies and almost 80 degrees here on Saturday which is unheard of in Seattle in May. I think this is going to be a warm one.
I got all of the spars in with openings for the Skylight and Fan. I remembered to drill wiring holes through the spars before I got the bendy board installed. I have run the wiring for the brakes and trailer lights and there isn't much room for the cabin and galley electrical wiring so I'll probably have to make more holes. Hopefully, I' bee able to get the drill in between the spacers.
- The spars fitted for skylight and fan
- w-TD-Cabin-Spars-IMG001.jpg (78.19 KiB) Viewed 1851 times
I was expecting the bendy board to be difficult to work with and it has. In my little space and my small table saw, I was challenged to get a straight rip to get the boards down from 60 inches to 58 1/4. Especially with the sheets not quite the same length.
- Getting ready to glue up the ceiling panels
- w-TD-Cabin-Ceiling-IMG001.jpg (78.82 KiB) Viewed 1851 times
I tried edge glueing the sheets together after they were cut to size in the hopes that there wouldn't be a seam. But it boards are just to thin to get a good seam. it worked here and there but I'll have to try something else.
- Weighing down the seam
- w-TD-Cabin-Ceiling-IMG002.jpg (84.23 KiB) Viewed 1851 times
