daveesl77 wrote:I have a 20"+ wide space that I use for cabinets and ductwork. Pull those out, install bunk bed and voila, room for 4, with floor space too.
dave
pchast wrote:IMHO... Do yourself a favor and run a ground wire to each light.
daveesl77 wrote:On the wiring, absolutely run ground and power wires to each component. Now, what I did was to create junction points at different areas of the trailer. Meaning "circuit A" is for interior lights, so I run a single 12 ga. feed ( + and - ) to 2 terminal strips ( one+, one- ) near where I planned to split off for the individual lights. I have an overhead LED strip, a small "reading" led light behind the head of each bed side, a small LED and an underbed LED. All are individually switched and 2 are remote controlled. So, from the junction points I can run much smaller wires to the LEDs, since they have very low amperage draws. This system is repeated for all circuits, both 12v and 120v.
dave
