Hatch alignment
Hatch alignment
Postby rainjer » Mon Jun 05, 2006 10:58 am
I think this question was lost in my othe post about my hatch.
How do you keep the galley hatch centered in the opening if you use a hurricane hinge?
I was thinling of useing some nylon tapered blocks at the top & bottom.
Any other ideas?
rainjer
King Koleman
Images: 11
Postby Gage » Mon Jun 05, 2006 11:29 am
I just stuck a screw in one end to act as a stop. I trimed off a little of the end of the flange common to the hatch ( just the part that is up in the 'C'). You don't even notice the screw.
Have a good day.
Image Image Image
Gage
Images: 28
Postby rainjer » Mon Jun 05, 2006 1:31 pm
I was wondering if that would work. I had a canopy on my truck they did that with.
rainjer
King Koleman
Images: 11
Postby asianflava » Mon Jun 05, 2006 6:41 pm
rainjer wrote:I was wondering if that would work. I had a canopy on my truck they did that with.
I wouldn't be suprised if it is the exact same hinge.
asianflava
Postby doug hodder » Tue Jun 06, 2006 9:53 pm
Rainjer...I'm thinking about making a couple of small wedges of polycarb/nylon, but a hardwood like maple will work...attach them to the sides up near the hinge on the interior wall, a low profile wedge will center the galley hatch as it closes and no visible screw on the exterior, but Gage is right, it wouldn't be that noticeable, just an idea....Doug
Postby IndyTom » Wed Jun 07, 2006 5:25 am
If you want to use a screw, but don't want it to show, use a grub screw. I would look like you had designed it that way from the start.
Never trust a skinny cook
IndyTom
Images: 42
