Hello all
Back again after another extended project hold time. Have had very little time to work on the tear. Stolen hour here and there. However the outside of my whole house and garage are now freshly painted. So I have been far from idle. Plus I've got quite the tan from that little painting project. As bad as the house needed the paint job, I was still sad to put the camper on hold for nearly all summer.
Did manage to get my doors and window openings cut out. I just finished fitting one door to it's opening today. Got a nice more or less 1/4 inch gap on the sides of the door. For whatever reason the top and bottom came out at 5/16 inch gap. Not too worried about that as I can fix that easy enough along bottom edge of opening if needed.
I also got my front head board cabinet sides cut out too. Plus got my windows fitted into both doors. It's great to be back at work on this project!
I'm fairly excited as I have decided to take a teardrop staycation from work!! I've got the first eleven days of October off!! I hope to make some real progress. Vowed to put everything else on hold for once, and just work on the tear all day, everyday!!!! Really looking forward to it.
Staycation Goals are:
1. Get my floor platform built, insulated, and bolted down to chassis. I went overkill on it's design. When I had the side rails cut off the original trailer it got real "flexy". So I hope to put some strength back into chassis with a beefy platform. Platform will be 3/4 ply bottom layer. !" thick inner frame and foam insulation. Followed with a 1/2 ply top layer. Screwed and glued together and bolted to frame with 12ea. 5/16" bolts.
2. Get the side walls stood vertical on floor platform. Then mock up a few different ideas I have for interior cabinets and galley design.
If all goes well maybe start some of the cabinet construction too.
3. Have a rolling shell of the camper upright and mobile, with some cabinets underway (or maybe 1 complete?) by the end of the vacation time. I want to be able to roll it it to the side of garage to store it inside for the winter.
The tear will end up skinned with PMF and painted. Just bought my Harbor Freight canvas drop cloths yesterday. The cloths are a great deal for that much 10oz canvas.
I have also decided to add A/C to the camper as well. I have an idea for a slide out unit that should work well. I'll know more when I get the walls up and can mock up the rear upper cabinets.
I'll post more pic's as I make some progress.
Door side gap:
- fit2.jpg (156.86 KiB) Viewed 10108 times
Top door gap:
- fit.jpg (141.98 KiB) Viewed 10108 times
Door window:
- door.jpg (170.3 KiB) Viewed 10108 times
