All along in our many discussions of materials to use for floors .. Plywood always comes out the winner , and then the loser ... Easy to cut and fit as a sheet , But weakens with any water intrusion (that spreads) ... so we slobber it with the Mix , smear black nasty stuff on the bottom , paint the top , and hope for the best . But while all this is going on , my all steel cargo trailer (homemade) , has a floor made from boards ... just plain boards ... untreated on the bottom , no BNS, and some linoleum thrown over the top ... and it’s in Great shape although being much older than anything I have ...
We notice , the Old timers used board floors too ... likely economic, but then again , many of those trailers lasted a long time ... and some didn’t ...
Also with a board floor you could build up the edges to provide more foam gluing area , or even run the foam below the floor as a “skirt" (or drip edge) ... And you could even use stronger species of wood for the high stress areas , and lighter wood for the rest ...
Always trying to think of ways to make a Foamie Better ... My next trailer might have a board floor ...
