Ned , sounds very doable ... Could be really Simple ... You have plans ?
Hint : if you’re going to cover anything inside , best do that before assembly when it’s easy to do ... then glue it all together. fabric and all ...
Ned B wrote:Oh I think the gentle curve of the Benroy is easy enough I'll see what the foam will do & if need be kerf cut the curve. Or I can use 1" or a sandwich of 2 1" pieces whichever...
