After our recent trip to the Gila hot springs in New Mexico (see Trips, Pics & Highway tales), the DVD player had bounced around enough on the top shelf to unplug itself (take 35 in, not 15!). I decided to use a bungie cord to hold it in place & it's better now. It has a stop knot on one end & a hook for the screw-eye on the other. It's good to hold things in place & hold a DVD or two on top as well.
Ran a new HDMI cable that was longer (just in case) and had to move the TV on its mount to open the access panel, which is a door to the back of the wiring chase.
Here's what the back of the PD4045 looks like, with the TV in the "down" position & the wiring where it all comes together (lights, solar, stereo, etc.), access panel is open, as well as the top cover inside the back of the shelf. It's 10# of you-know-what in a 5# bag.
The most recent addition to this mess is in the top-left corner. It's the 3rd brake light control module which takes the wires from the stop-turn signals on both sides of the lights & converts them to make the 3rd brake light work without having it blink, if brakes are applied & the turn signals are being used at the same time.
This could have been done a bit neater, but it all works well enough.
There are still a few 12 volt circuits available in the PD4045. The red wires with tape on the ends are the open circuits without fuses in place. It's really a nice panel to use & install, just a PITA if there as many things going on as we have in our camper.
Here's a list of things we have & use regularly
2 - Cabin reading lights (all lights are LED type)
2 - Cabin dome lights
2 - Porch lights
1 - MaxxAir 10 speed fan
3 - USB charging ports, 2 cabin, 1 galley
2 - 12 volt car-type plugs, 1 galley, 1 cabin
1 - Car stereo with amplified shark fin antenna
1 - 22" flat screen TV
1 - BluRay DVD player
1 - Sound bar (35 watt)
1 - Small inverter for TV system in cabin (200 watt PSW)
1 - Large inverter for the galley (1000 watt PSW)
1 - 100 watt solar panel
1 - 110v galley outlet from the inverter (coffee grinder)
1 - 110v galley outlet for shore power
1 - 110v headboard outlet for AC unit
1 - Group 27 AGM battery
1 - Large size bit of Luck to make it all stay working!
