H.A. wrote:How about eliminate the electric requirement all together.
Some idiot needs to suggest cryogenic cooling. A cryogenic cooled railcar can stay cold a couple of weeks. Scale that down to teardrop size... A couple weeks is a decent time for a camping trip.
aggie79 wrote:Here's a 2500 Btu unit: http://www.climaterightair.com/products/climateright-2500-btu-mini-ac-heater.html for $399.
daveesl77 wrote:Edit: Did the secondary test and yep the initial current draw is just a bit too much for the inverter. Now to see how the hard start works, or not. Supposed to get here next week. The dorm fridge fired right up and no I didn't try them at the same time.
Shadow Catcher wrote:Kimberly Karavans has an article/Ebook where they discuss solar/battery/AC Basically convincing you need a LOT of battery and a LOT of solar and a 1000W generator and a AC unit with a hard start capacitor.
RonS wrote:Would using dual batteries, in series for 24V be a solution? I know they make 24V DC to 120V AC inverters. One that I saw said about running refrigerators and microwaves....
Yes, we're having to adapt to the realities of the marketplace (very small capacity AC units--less than 5K BTU-- are not mass-produced "commodity" items, so they are expensive), and also probably physics/engineering (for whatever reason, as we go down in size, these units appear to produce less cooling per watt consumed). Still, if we can stick with the 5K BTU unit and introduce some thermal mass, maybe we can dehumidify that air more effectively. The problem you cite happens in home AC units when they are "oversized", and therefore they don't have to run very long to get the home cooled down. As a result, a relatively small amount of the home's air gets routed over the evap coil with the resultant removal of moisture. However, if we had some thermal mass immediately downstream of the evap coil (think a bunch of full AL cans, each wrapped with simple heat sink of aluminum fins, or something similar), they'd be cooled down by the AC unit and the air that comes out of the system and into the living compartment would be warmer than it otherwise would be (because it got warmed a little by the cans), so the AC would run longer each time. At the end of the "run" we can continue to run a fan over the cans to take advantage of their coolness, and if they remain below the dewpoint of the cabin air they'll continue to remove moisture (gonna need a pan under them and a drain).RonS wrote:Also, you don't want to oversize the A/C unit where it only runs a couple minutes at a time. That doesn't allow it to properly dehumidify the air and you end up cool, but clammy/damp.
daveesl77 wrote:The reason the 2k inverter is kicking off during startup is two-fold...
1) Required starting amperage on a compressor can be 3-8 times the under-load amperage. So, a 500 watt running load can hit possibly 4,000 watts for a few seconds at start up, but probably more in the range of 2,000-2,500 watts.
2) The inverter I have is a cheap model and the AC is also a cheap model (goldstar), so neither is efficient at doing their job. They both do what I got them for and I only paid $40 for the inverter and $20 for the AC, so even if they won't work well together, they do work well separately.
dave
