Tucson tortoise: Edit for photos
Re: Tucson tortoise
Postby noseoil » Thu May 12, 2016 6:28 pm
From a few years ago, here's the Salt Flat Rat from Washington State.
160253
Just a couple more, for fun.
160252
160251
160254
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby S. Heisley » Thu May 12, 2016 7:57 pm
That tail on the "rat" is funny! :lol:
Re: Tucson tortoise
Postby noseoil » Sat May 14, 2016 2:06 pm
Working on the doors again. Here's the galley with things roughed-in, prior to final sand & stain.
160255
The interior doors in place
160257
Stained & drying on the porch, next step will be a few coats of urethane.
160256
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby ratrod71 » Sat May 14, 2016 11:38 pm
Very nice!
Alaskan Benroy build journal: viewtopic.php?f=50&t=61738
ratrod71
Re: Tucson tortoise
Postby badschnauzer » Sun May 15, 2016 1:44 pm
Looking good! :thumbsup:
Posted by: BadSchnauzer
Colorado Springs, CO
See my Pikes Peak Woody Build
Image Image Image
badschnauzer
Images: 194
Re: Tucson tortoise
Postby KCStudly » Sun May 15, 2016 5:41 pm
I like. :thumbsup:
Re: Tucson tortoise
Postby OP827 » Sun May 15, 2016 6:24 pm
I like it too.
OP827
Images: 405
Re: Tucson tortoise
Postby Atomic77 » Tue May 17, 2016 12:33 am
Looking really good! Cabinet doors look great and I like the port hole. :thumbsup:
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: Tucson tortoise
Postby noseoil » Fri May 20, 2016 12:18 am
Cabin doors are finished & hung now. Another item off the list, still a bit more to go to be done, but progress is being made. Sorry about the flash reflection on the screen. Too hot to set up lights inside now that summer's here again.
160258
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby Vedette » Fri May 20, 2016 12:45 am
Are those handcuff mounts in the corners?? :twisted:
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Tucson tortoise
Postby KCStudly » Fri May 20, 2016 6:36 am
That is looking really nice! Ya' dun' good. :thumbsup: :applause:
Re: Tucson tortoise
Postby noseoil » Fri May 20, 2016 7:59 am
Here's the galley. Did the doors, hardware & finished the upper doors. Need to do a lower drawer for the skillet & sauce pan. It'll sit between the cooler & stove.
160261
160262
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby noseoil » Sun May 22, 2016 9:06 am
Progress! Here's how it looks now with things finished & in place.
160263
Ball catches for the doors, PITA to set up, but they work well enough & keep the doors shut when travelling. The doors are square lip edged in the center (mistake I won't go into here) so only one catch is needed for the pair. One door holds the other closed due to the overlay.
160264
Open, some stuff inside, finally! Nothing to fall out now on a bumpy road.
160265
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby noseoil » Sat May 28, 2016 9:13 am
It's been bugging me since I did the headliner. The canvas I bought said it was "60 inches" wide. The cloth was actually 58" wide, so I had a gap of about 3/8" at each edge on both sides where the ceiling meets the walls, the entire length of the cabin.
Made a couple of flat trim pieces to do the edges, stained, finished & installed them. Here's the back at the cabinets above the port holes.
160266
This is the front at the headboard, where the curve starts at the front radius.
160267
Will be working on the air conditioning this weekend, just in time for summer (actually it's simmer here now).
137905
noseoil
Images: 669
Re: Tucson tortoise
Postby ratrod71 » Sat May 28, 2016 3:45 pm
Amazing workmanship. You Da Man!
ratrod71
