Took last Friday off and worked on the camper. I have officially reached that point of questioning my sanity and ability.
First I wired the 12 volt system using some diagrams and forum posts and the zero skill that I possess. Amazingly all of the various outlets and fuses appear to work.
I have a 6 fuse box that is wired as
1. Battery voltage meter
2. USB ports (x2)
3. Cig ports (x2)
4. Actuators
5. Future vent fan
6. Future dome light or?
7. Should have order the 12 bank model - grrr.
Next I installed the actuators and wired that little gem. Essentially there is 1 line from the battery to the switch and then the switch is daisy chained to each actuator around the camper. I decided to forgo the remote control wiring until a later date and my brain would not process the extra wire schematics.
Finally, I built a collapsible table out of some scrap walnut and cherry I had in the shop. It still needs some work to increase the stability when deployed. In the stowed position it builds out more the sleeping area making it full width to almost our hips. Not sure if we plan to widen the leg portion - probably do a test run or 2 before decisions are made.
Believe it or not that finishes the lower half for now. Of course there is always some fiddling to do, but I plan to keep it open until we start using it and determine what works for us and what needs changing.
Next steps - begin the roof work.
- camp5.png (522.5 KiB) Viewed 2031 times
- camp6.png (580.64 KiB) Viewed 2031 times
