- Window AC with powered 60 CFM exhaust
- 20160829_093809 (2).jpg (131.63 KiB) Viewed 841 times
jasstack wrote:I would be sure and allow for condensation. I would recommend a drip pan, preferably with a drain to the outside (typically under the trailer). Or, you could do a traditional installation of the AC unit as I did, letting it drain outside as if it was mounted in a window in your house. If you have no condensation, that's great, but, if there is condensation, you don't want that water running where it shouldn't. Be prepared for all possibilities. I fired up my AC the other day and the condensation was almost running out the bottom of the unit. Granted, it was very humid (I live in SW Ohio where it can be 90% humidity for days), but I was glad I provided for the condensation drainage!
I've attached a couple photos of my AC installation. The unit is mounted on full-extension drawer slides. They are mounted in reverse of the typical usage, in that I push the unit out when parked and pull it inside when we break camp and hit the road. There is a door on the outside that seals the opening.
jasstack wrote:The door seals with D-profile-shaped door seal and stays closed with a simple lock. There are several different sizes of seal available. The seal is applied to the door stop. In addition to putting aluminum around the AC unit, I added one to the front bottom of the unit. This seal rubs lightly on the shelf. It isn't perfect and I will probably redo it a some point. I've attached a photo of a sample of a door seal.
hikerainorshine wrote:funny Bob, when I installed my old window until on the garage floor with duct running in and out of the teardrop windows, there was water everywhere. Now that I have it in the galley with powered exhaust, there is no water. We probably have 60% or higher humidity. For those who have lots of water, how long is your unit running before shutting off? Mine only runs for 3-4 minutes.
