Felixx's Superleggera - It is ROAD LEGAL!
Re: Felixx's Superleggera - It is ROAD LEGAL!
Postby Dusty-NZ » Sun Aug 28, 2016 3:03 am
The treated ply is going to have a nasty green tinge to it , FUGLY :(
BUT ........ if you use untreated then it will be best if you spend some extra money on a good quality marine finish for it. Then keep the TT in a shed when not in use. For what ever reason , the poly finishes seem to be more prone to weather deterioration than paint.
Looking forward to seeing it done :thumbsup:
Dusty-NZ
Images: 9
Postby felixx » Wed Aug 31, 2016 5:21 pm
How about marine ply?
felixx
Images: 22
Postby felixx » Wed Aug 31, 2016 11:47 pm
Gave my interior a coat of polyurethane today
Will do another coat in the weekend if it gets warm enough (love spring)
felixx
Images: 22
Postby Dusty-NZ » Thu Sep 01, 2016 12:25 am
I am of the opinion that "marine" is a marketing tool . I have been informed by my friend ( who builds caravans for a living ) that the adhesive bonding the plys is the same in both situations . It is still really important to seal the outer skin.
Dusty-NZ
Images: 9
Postby felixx » Thu Sep 01, 2016 12:38 am
thanks Dusty
So a good varnish and reapply it annually is the go?
I was pleasantly surprised that 750ml did the inside of mine and the hatch today
I reckon the 2nd coat will use less as the wood will be 'sealed' now
This was just some bog std polyurethane that the neighbour was about to throw out. I got 3L for nothing. It is only for interior use though
felixx
Images: 22
Postby dales133 » Thu Sep 01, 2016 3:29 am
Aussie hardwood ply is tbe go if you can find it there
dales133
Postby Dusty-NZ » Thu Sep 01, 2016 4:19 am
I agree with dales133 you might like to try http://bbstimbers.co.nz/products/panels/plywood/
Dusty-NZ
Images: 9
Postby KCStudly » Thu Sep 01, 2016 3:12 pm
Dusty-NZ wrote:I am of the opinion that "marine" is a marketing tool.
I call BS on this. BS 1088 (clicky link) that is. :lol:
Yes there is exterior grade plywood that uses water proof glue, but the species and quality standards are not the same.
I used 5mm marine grade spec Okoume for my interior and floor skins, as well as my cabinet shelves, and I couldn't be happier with the quality. Extremely few defects, voids, only a few tiny tiny knots, etc. Sometimes I think the back side was better than the front!
Postby Dusty-NZ » Thu Sep 01, 2016 3:40 pm
Thanks for the link KC , nothing quite like a bit of research eh, :)
I thought this
https://en.wikipedia.org/wiki/Plywood#Marine_plywood
showed similar glues in both exterior and marine products , but I see there are many more variations available if required. :)
Dusty-NZ
Images: 9
Postby felixx » Sat Sep 03, 2016 5:57 pm
https://touch.trademe.co.nz/listing/view/1154711337
What do you think of this stuff dusty? Dale?
It is purely cosmetic / non structural
In other news the interior of my td now has 3 coats of polyurethane
Is much nicer
felixx
Images: 22
Postby Ned » Sun Sep 04, 2016 4:39 pm
i used 3mm caravan finishing ply on the inside of my teardrop...
http://pprpenrose.co.nz/product-categor ... -decolite/
fairly cheap, lots of types available. Not sure how well it will work on the exterior though?
Just use aluminium ;)
Build Journal :: My Grumman 2 (ish) TD
Ned
Postby felixx » Sun Sep 04, 2016 5:40 pm
Thanks Ned
But wood is what mother bear wants too..
felixx
Images: 22
Postby Ned » Sun Sep 04, 2016 7:42 pm
i think i'm going to vinyl wrap my aluminium this year...
Might see if theres a wood grain wrap i can use :P
Ned
