bobhenry wrote:your album shows a single tongue and not an "A" framed tongue. I think you will find that the tongue stops at the 2nd cross member. as the now extended tongue lifts it uses the first member as a fulcrum and then exerts down pressure on the 2nd member. My Namco trailer had been overloaded and the 2nd member was bent downward. I replaced the tongue but extended it the full length of the trailer and then added an additional 18" to get better backing and road towing manners. The 3/16 2x2 tongue proved to be a bit anemic for the job. I later added a flat strap truss to overcome this problem. I would strongly suggest a 2 x 3 x 3/16 of perhaps a 2x2 x 1/4 wall structural tube. I liked the 2x2 because I could extend over the axle without worry and the stub at the other end could b drilled for a bike rack or other hitch accessories or maybe another hitch ball .
You can see the bow string truss under the tongue in this picture. The vertical is actually the front of the frame the body is extended 2 feet forward of the frame.
![Image](https://www.tnttt.com/gallery/image.php?image_id=54901)
here is an older post .....
viewtopic.php?f=35&t=63983&p=1139411&hilit=truss#p1139411
Hi Bob,
Thanks for the reply, and I did look at that other thread.
Yes, my designs in my album show a straight tongue. That was when I was planning to use an old utility trailer that I have on hand, it actually has 3"x3".
However, I changed my plans, and got a really good deal on a Northern Tool 5'x8' aluminum trailer. As such, I do now have an "A" frame tongue. Well, that is, when I actually assemble the frame... it's still in boxes.
However, I am designing in sketchup, and based on my design, I will need an additional 12-15 inches forward of the original tongue location.
I haven't posted any updated design pictures, as I keep revising. I will post my design up when I get to where I think it's done and ask for feedback at that time. I would drive the board crazy with revisions, as I think I've gone through about 20 or more since posting the original designs.
I have seen where the NT trailer is easy to extend by flipping the top bracket and then extending back to the first 2 cross-members. This allows bolting to those cross-members, as well as a solid bolting position at the point in the A-frame.
All that being said, will I still need the 1/4" or will the 3/16" cover it?
