pchast wrote:I'm confused. I used a circuit from Amazon (Pacer Performance 20-702 Black Logic Circuit). This took input from the turn signals. If both were on the third brake light lit.
Are you trying to do the same or to change your TV wiring to the trailer?
Camp4Life wrote:Lastly, if you happen to have a 5 or 7-pin connector on your TV for brakes, you can use the electric brake pin to trigger the 3rd brake light on the trailer as well since that only gets power when you brake.
RunnerDuck wrote:Camp4Life wrote:Lastly, if you happen to have a 5 or 7-pin connector on your TV for brakes, you can use the electric brake pin to trigger the 3rd brake light on the trailer as well since that only gets power when you brake.
BINGO!!! Thank you "Camp4life" I do believe that's the answer. I do not have electric brakes on my TD so that should be the perfect solution.
Thank you so much for that suggestion.
Now the question is: "I also pull a big fifth-wheel with my truck and it has a break controller on it. I wonder what effect that will have on it.
I assume that the voltage is controlled by the break controller so it might only come on to full brightness when I press hard on the brakes. Hum?
