clip wrote:Hi,
I'm looking for someone that has done this type of wall construction to either talk me out of it or Help walk me through it, I've got some spefic questions and might need a couple phone calls for explanations that get to wordy for print.
My gratitude and some beers is about all I can pay.
MS
clip wrote:My plan is to use 1/8? Inch plywood in 1 1/2 wide strips (width depends on the least waste) bent around a continuos form front to back glued etc. I made tobbogins for the kids it's not the bending part but more the details like feathering the ends at the bottom plate gauging spring back if any and so on. I'm building 3 complete trailers to start so I wanted to continue building more walls as I go and let things dry and work the rest of the build.
