More pics, chassis is painted and the drop floor started. I cut out one cross member of the frame and figure that 3/4" treated plywood glued and screwed to the under side of the frame would give it back some of the loss in strength.
Starting the drop floor.jpg (239.06 KiB) Viewed 4998 times
This is how the floor was attached and pieced together. After the walls were up I checked to see if I could get the tires off, NO, so I ended up cutting away most of the wood rail that goes along the outside part of the wheel wells.
Camper floor progressing.jpg (243.44 KiB) Viewed 4983 times
camper floor progress.jpg (208.14 KiB) Viewed 4983 times
When the first sides went up it was windy so I used the foam cut offs as braces for the sides. I fastened the back wall to the sides with 4" screw with washers on them, which pulled it tight until the G-glue dried, then I took out the screws for re-use.
Walls, and ends.jpg (145.32 KiB) Viewed 4953 times
