New Pace 6x10
New Pace 6x10
Postby MADTRAPPER » Thu Oct 27, 2016 7:54 pm
Finally got my 2017 pace. Hunt and fish in northern Canada. What's the best way to insulate this. Thanks. ImageImageImageImageImage
Sent from my iPhone while suiting on toilet.
MADTRAPPER
Re: New Pace 6x10
Postby Padilen » Thu Oct 27, 2016 9:43 pm
Nice trailer, like the RV door with screen. And the higher window. How much does your roof vent rise above your roof?
I don't know the best way, I know the common way. Ridged foam insulation. I think sprayed on would be best but $.
Padilen
Re: New Pace 6x10
Postby MADTRAPPER » Thu Oct 27, 2016 10:06 pm
Not sure about Roof vent. Not sure how much room there is between the plywood and outside wall. But ridged foam be the best way I think. Will be working on it all winter have heated shop.
MADTRAPPER
Re: New Pace 6x10
Postby mkitchen » Fri Oct 28, 2016 11:12 am
I am going to have to follow along with this thread. I am thinking about building up a cargo trailer as well. Nice looking start you have there.
Many years ago, I worked for a fiberglass manufacturer and we used to make insulation for aircraft as well as home. I wonder how that would do for a trailer but I would not know where to find it either.
Mikey
mkitchen
Re: New Pace 6x10
Postby MADTRAPPER » Sat Oct 29, 2016 10:35 am
Thanks. The roof vent is appropriate 41/2 in total height of trailer with vent is 8 foot. I can put 1 1/2 in. foam on roof. The sides look like 1 in.
Sent from my iPhone while sitting on toilet.
MADTRAPPER
Re: New Pace 6x10
Postby MADTRAPPER » Sat Oct 29, 2016 10:37 am
Another question why is the inside of roof not sheeted in with plywood??
MADTRAPPER
Re: New Pace 6x10
Postby jandmz » Tue Nov 01, 2016 10:53 am
MADTRAPPER wrote:Another question why is the inside of roof not sheeted in with plywood??
I'm sure THEIR reasoning has to do with production cost, but, I'm looking at it and thinking, "look, they left it open to make it easy to run wiring!" :)
jandmz
Re: New Pace 6x10
Postby MADTRAPPER » Tue Nov 01, 2016 4:32 pm
I'm thinking the roof is square tubing could a guy drill some holes in it and use spray foam to fill up the inside of the tubing.
MADTRAPPER
Re: New Pace 6x10
Postby Padilen » Tue Nov 01, 2016 7:49 pm
MADTRAPPER wrote:I'm thinking the roof is square tubing could a guy drill some holes in it and use spray foam to fill up the inside of the tubing.
I wondered that myself with my trailer!
Didn't try it.
Padilen
Re: New Pace 6x10
Postby MADTRAPPER » Tue Nov 01, 2016 8:03 pm
Yea maybe someone on here has done it. Have to do some more research.
MADTRAPPER
Re: New Pace 6x10
Postby jandmz » Wed Nov 02, 2016 10:11 am
I don't think I would fill the tubing with foam. Even if you get a good fill, foam can absorb and hold moisture, which could cause the tubing to rust from the inside out. I would leave it as it is.
jandmz
Re: New Pace 6x10
Postby MADTRAPPER » Wed Nov 02, 2016 10:23 am
Thanks.
MADTRAPPER
Re: New Pace 6x10
Postby MADTRAPPER » Mon Nov 07, 2016 6:22 pm
Still getting supplies for the build. ImageImageImageImage
MADTRAPPER
Re: New Pace 6x10
Postby MADTRAPPER » Fri Nov 11, 2016 2:24 pm
Painting the walls white. Don't know what to do with the floor. Thinking some kind of gray paint.
MADTRAPPER
Re: New Pace 6x10
Postby MADTRAPPER » Sat Nov 19, 2016 2:08 pm
Stating to insulate. Hunting finished now. ImageImageImage
MADTRAPPER
