rustytoolss wrote:Since I have not yet started my build. What about just gluing wood support directly to the foam without cutting a channel (in the interior) ? Would this create a problem ? or lower structural strength ?
KCStudly wrote:Chiming in, aye. My thoughts always seem to go back to the old "outer fibers" mantra. The strength of the skin, be it canvas or plywood, comes from it being the unbroken fibers in the outer most fibers in the panel member (be they inside or outside of the camper). When a load tending to bend or deflect the panel occurs, those outer fibers try to stretch or compress, depending on which side of the wall they are on. Now most materials (all?) are stronger in compression than they are in tension so we are mostly concerned with the strength of the outer most fibers in tension. This is where the canvas/fiberglass/plywood excels, it is really strong in tension compared to the foam. The foam isn't all that strong except when we consider it in large areas. In other words, if I poke it, dent it, or snap it in a line it won't take a lot of force to fail, but if I spread that force out (using canvas, FG or plywood) over a larger area the numbers go up dramatically.
Not that it was proposed, but what you really don't want to do is apply the stick framing to the surface of the foam and then try to skin over the irregular surface. For one the "sheet goods" are far easier to apply "in the flat"; you will have trouble getting it to lay into and stick in the inside corners. But the bigger reason is that you have now interrupted all of those fibers that no longer have a straight line of tension. Essentially you will have created a stretchy spring. So if you plan to surface mount sticks, do it after the skinning. For an afterthought addition such as a kids bunk, or internal support for a roof rack, this is a decent compromise, but for my sense of aesthetics and design I wouldn't plan it this way from the start.
Again, maybe the loads are small enough, and the structure strong enough to get away with just about any configuration, but why not optimize every aspect with good design practice? Done right you can have a litter structure that is as strong, or one that weighs the same and is stronger.
Here's another way of looking at it. Which do you think is stronger, if I glue the head of a bolt onto a flat surface and then pull and pry on the threaded end of the bolt, or if I run the bolt thru a "plate" with a washer under its head and then pull on it. The glued on bolt is only as strong as the glue joint and the fibers immediately surrounding the joint and is less capable of handling lateral forces (side leverage), whereas the thru bolt distributes the load over a much larger area of the wall, taking advantage of the unity of construction as well as having more lateral support. Embedding the stick members in the foam behind the skin is essentially the same as thru bolting with a washer.
Also, from an appearance and comfort level (i.e. not bumping into edges or sleeping up against a lump) I like smooth walls better.
Pays yer money and makes yer choice.
rustytoolss wrote:Do you line the notches with canvas (making them somewhat wider) for extra strength ? I would doubt it, but just asking.
