Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby friz » Sat Dec 10, 2016 7:48 pm
Today we sandImage
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Postby friz » Sun Dec 11, 2016 6:32 pm
Back to shinyImageImageImageImageImage
The "Sin Bin"
150133
friz
Postby MadMango » Sun Dec 11, 2016 6:52 pm
Looks smoooooth!
MadMango
"Art without engineering is dreaming; Engineering without art is calculating." ~Quentin Stafford-Fraser
You can see my design planning, The Mobile Mango.
You can follow my TTT build here, The Mobile Mango
MadMango
Postby friz » Mon Dec 12, 2016 11:15 pm
The "Sin Bin"
150133
friz
Postby MadMango » Tue Dec 13, 2016 9:20 am
Looking good! I bet that first hole through the outer skin for your door was pucker-inducing.
MadMango
MadMango
Postby friz » Tue Dec 13, 2016 10:04 am
MadMango wrote:Looking good! I bet that first hole through the outer skin for your door was pucker-inducing.
Yes it was.
The "Sin Bin"
150133
friz
Postby Pmullen503 » Tue Dec 13, 2016 10:21 am
Will the inside be glassed or just coated with resin?
Pmullen503
Images: 67
Postby aggie79 » Tue Dec 13, 2016 11:48 am
I was thinking the same thing. As beautiful as the outside looked, I can't imagine the pucker factor! :? I don't think I would have had the courage to make those cuts.
Postby Alan_H » Tue Dec 13, 2016 2:03 pm
I've been away from the forum for a while. Very glad to see someone on here doing a build for the CLC Teardrop.
I'm working on a design in Sketchup to build a teardrop in the stitch & glue method. Mine will be slightly bigger, not not nearly as pretty.. :)
What thickness is the plywood for the shell? Also, are the inner panels, such as the galley deck and bulkhead the same thickness?
Thanks for sharing the process with us, you're doing beautiful work on this.
Alan_H
Postby booyah » Tue Dec 20, 2016 8:04 am
friz, jus wanted to say it looks awesome!
Loving the looks of that, and I had to exhale when i saw the pic of the door cut out. Gawd that had to be scary!
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby friz » Fri Dec 23, 2016 12:02 am
The "Sin Bin"
150133
friz
Postby friz » Sun Dec 25, 2016 11:41 pm
Test fitting essentials.
The "Sin Bin"
150133
friz
Postby friz » Mon Dec 26, 2016 4:04 pm
The "Sin Bin"
150133
friz
Postby friz » Mon Dec 26, 2016 10:13 pm
The "Sin Bin"
150133
friz
Postby friz » Mon Dec 26, 2016 11:26 pm
The "Sin Bin"
150133
friz
