rustytoolss wrote:Thank for the information, I just built my own hot wire cutter. It worked better that I expected. About the only problem I had, was the circuit breaker kept cycling. I have a transformer from a HO Trains set from about 20 years ago. Going to try that.
rustytoolss wrote:At this point I'm using 1/16" wire for torch Oxygen/Acc welding. As it was the only wire I had small enough to test with. And I will need to use it with the transformer / for now anyway. Do you have any pictures of you hot wire cutting tools ? they may give me some ideas. Merry Christmas
