dancam wrote:I havent yet, but am planning to mount it under the trailer close to the axle.
les45 wrote:I have not mounted my spare tire on either of my builds. I simply carry it along with my trailer tool kit (spare hub, wrenches, etc.) in the back of my TV when traveling. I keep it stored in my garage mainly to keep it from deteriorating from outside storage. I also keep my two trailer tires coated with Armorall and covered when not in use. I've found that tires deteriorate more from exposure to the elements during storage than they do from actual use.
RonS wrote:Having worked at a garage that also did towing and roadside assistance, don't mount the spare under the vehicle. If/when you need it and you're out and it's rainy/snowy/muddy etc you'll thank me. Also remember, your trailer isn't going to be as high off the ground with a flat tire, and you should NEVER be under a vehicle supported by a jack.
