ssrjim wrote:
bdosborn wrote:ssrjim wrote:
Inside/outside TV? Brilliant if it is and I totally would have copied it for mine.
HotRod1 wrote:Did you make your wheel tubs or are they the ones summit sells?
Looks great I think I need one behind my 67
aggie79 wrote:Jim,
Everything is looking fantastic! Would you mind a couple of questions? Are you using pre-finished plywood for most of the interior or are you applying finishes before installation? Also, what type & thickness of plywood are you using for your roof (and front and back)?
Take care,
