tony.latham wrote:I too think something is outgassing from under your tar. What exactly is the product you used? Can you post a link to Home Depot's webpage? I'd probably suit up and start scrapping it off.
And your epoxy, what brand did you use? I gotta believe it's gotten harder by now. There are some epoxy hardeners that are a slow set.
TL
The bubbling actually stared on the wood edges and then to where the foam is.
tony.latham wrote:The bubbling actually stared on the wood edges and then to where the foam is.
Is the black-goo directly on foam, or is the foam inside the floor and it's covered in plywood? (Hitches like this tar problem are why teardroppers lay awake at night and study the dark ceiling.)
Assuming you correctly mixed the epoxy it'll be just fine.
tony.latham wrote:If I understand it, you put the goo down, then the foam over the top and more goo slathered on top of that? Could the bubbling be coming from the space between the foam and the plywood? (outgassing around the sides of the foam?) The expanding fumes hit the semi-dry surface and starts bubbling.
Is that possible? If the floor turns into something you can't work with, seal your second one with epoxy.
Atomic77 wrote:I'm not a fan of the tar and won't use it for messy reasons such as this. I'm with everyone else... seems like outgassing to me. As KC asked, is there any degradation of the foam? Solvents and foam don't mix. As for the epoxy... Cool temps will greatly affect cure rates. I would be more interested though in knowing how you mixed the epoxy. Did you use the premeasured pumps? Or a mixing cup with graduations? I've used a lot of West Systems. Literally 55 gal barrels of the stuff. Accurate mixing is critical.
KCStudly wrote:Sounds like the solvent in the tar is melting the foam. Any signs of degradation (gooey-ness) in the foam?
On the epoxy, when working at the low end of the manufacturers stated temperature range, you want to give it a little extra time in the cup to get the exothermic action started before spreading it out. if you don't stir it adequately, or it is too cold and gets spread too quickly, it will either take a long time to cure, or won't cure; either way you probably will never develop full strength (not as important when being used as a sealer, but may make a difference when used structurally).
Wests System Use guide for cold temperature bonding
"4. Stir the resin and hardener thoroughly. Mix the resin and hardener longer than normal (two minutes minimum) and scrape the sides and bottom of the mixing container. Use a mixing stick shaped to reach the corners of the pot. For a given volume of resin and hardener, a smaller diameter mixing pot will improve the chemical activity because the limited surface area will not dissipate heat produced by the chemical reaction."
dakippen wrote:Atomic77 wrote:I'm not a fan of the tar and won't use it for messy reasons such as this. I'm with everyone else... seems like outgassing to me. As KC asked, is there any degradation of the foam? Solvents and foam don't mix. As for the epoxy... Cool temps will greatly affect cure rates. I would be more interested though in knowing how you mixed the epoxy. Did you use the premeasured pumps? Or a mixing cup with graduations? I've used a lot of West Systems. Literally 55 gal barrels of the stuff. Accurate mixing is critical.
The foam seems to holding up quite well - just bubbles on top, both the wood and foam. It's still dry to the touch, but with a little bit dripping down
The epoxy came pre-measured in, all mixed into one bucket and then followed directions. Even set a timer on both how long to mix and how much time we had to spread...that too seems to finally be setting up.
dakippen wrote:Atomic - I pretty much believe you hit the nail on the head with both...building a teardrop in February in MN is probably not the best thought out plan....
