QueticoBill wrote:I have been sketching and looking at products for building doors on my slow-to-get-going build and I feel like I can build a more weatherized seal by going flush, using to rabbets so the door overlaps in a way, with a silicon or qlon kerf seal compressed at the overlap. If the door is proud, It seems it will always be tough to not channel water into the gap at the top and, while moving, the forward edge.
KCStudly wrote:The wiley window frame looks like it might be close enough to the edge of the door that it will catch on the jamb when it swings. If you haven't already checked for that you can strike an arc from the hinge center and see if it crosses.
