duke wrote:Looking good, Steve. Love the profile. How thick is the plywood the drop floor is made of?
bdosborn wrote:I bet the key for your baggage door is a CH751. That's what all of mine were...
OP827 wrote:I like your build and your idea of tilt-out. Did you see cabana caravans? Hardwall tiltout or slide-out maybe ?
https://www.facebook.com/CabanaCaravan
Woodbutcher wrote:OP827 wrote:I like your build and your idea of tilt-out. Did you see cabana caravans? Hardwall tiltout or slide-out maybe ?
I had been playing with a tip out like that last week. Still trying to figure a good way to seal it up.
OP827 wrote:Woodbutcher wrote:OP827 wrote:I like your build and your idea of tilt-out. Did you see cabana caravans? Hardwall tiltout or slide-out maybe ?
A slide out instead of tip out could be easier, more economical to fabricate and seal. Provides more space too. That is perhaps why we don't see too many tip-outs on the road like that.
I looked at some slide-out patents and noted that main idea is to keep bottom edge seal more recessed inside the wall so that water drops from the top and sides edges can run down. For top and sides the sealing edge could be approximately in the middle of wall or even at the external surface, while bottom edge is about inside the wall thus creating a gap for water to freely run down. Slide guides and horizontal surfaces may have to be slightly slopped towards exterior as well, so the water does not crawl inside. For such relatively short and light slide-out, this seems to be achievable?
QueticoBill wrote:OP827 wrote:Woodbutcher wrote:OP827 wrote:I like your build and your idea of tilt-out. Did you see cabana caravans? Hardwall tiltout or slide-out maybe ?
Interesting idea. Why not a slide out that has a bottom, sides, and end - opened on top and of course inside - and a top hinged "top" - which would seem easier to seal and latch against wall - or even inset into a rabbet or recess in the wall. When it's open, the sides with a sloped top would meet the top hinged top, and shed water. The top probably wants to be several inches larger than the the slide out "box", to shed precipitation when set up.
Could be improved with the latch being inside, so just unlatch and push box out, raising the top on plastic sliders or rollers.
Users browsing this forum: smeerkees and 10 guests
