Local sources for butyl tape?
Postby booyah » Tue Apr 11, 2017 7:39 am
So my TD started leaking by the fantastic fan. When I installed it (two years back) I did so with 100% silicone, but it appears to be suffering from the heat cycles, and appears to be the weak point.
I know I can order like 30ft of butyl tape from amazon, but I'd rather buy it locally. My local home depot, lowes and menards dont carry it, but I wondered if I was overlooking another possible source.
Any help on where to find it?
Background info, td is stored outside in Michigan. Anyone local knows what that means, lots of rain, snow, and bad things, lots of temp swings (30-40 degrees in a day is not uncommon). Its tarped over the winter so snow build up doesnt compromise the vent seal. I found the leak just before I tarped it for the winter, and it was a very mild leak. Got the mattress and bed clothes out, and tarped her up. I've checked a few times since the tarp went on and shes dry right now.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Re: Local sources for butyl tape?
Postby QueticoBill » Tue Apr 11, 2017 7:46 am
Not sure the tape is best but I got it from a glass store. Used all the time for big windows - plate glass in a frame.
QB
QueticoBill
Images: 22
Postby John61CT » Tue Apr 11, 2017 9:28 am
John61CT
Postby Gladtobehere » Tue Apr 11, 2017 9:37 am
Any RV shop should have it.
Gladtobehere
Postby MtnDon » Tue Apr 11, 2017 1:28 pm
Metal (home and commercial) roofing suppliers
MtnDon
Images: 24
Postby GuitarPhotog » Tue Apr 11, 2017 3:40 pm
https://www.vintagetrailersupply.com/Bu ... ts-419.htm
Not local but the right stuff, instead of almost the right stuff.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby booyah » Wed Apr 12, 2017 7:11 am
GuitarPhotog wrote:https://www.vintagetrailersupply.com/Butyl-Putty-Tape-p/vts-419.htm
<Chas>
:beer:
for varying levels of local... theyre about an hour away from me :D
booyah
Postby JuneBug » Fri Apr 14, 2017 3:58 pm
Gladtobehere wrote:Any RV shop should have it.
That's where I found mine. It was a small project and they sold a partial roll to me at a discount price. If you can get it at an RV place that does repairs, perhaps they would sell it by the foot, so you're not stuck with a giant roll.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
