Tying two previous threads together here.
(thread 1)...I was looking for items to "test weld" together, after buying two different welders to learn to use in future projects (I never welded before, and would be my own teacher); I found a chrome 2" hitch ball, and a leftover plumbing pipe (plus stanchions and a barbell collar). In my warped, Rube Goldberg-esque mind, I found a combination I could use to make a "limited-use" pushbar, to attach to my truck for pushing the TTT into the garage bay, rather than trying to do so by hand.
(thread 2)... I related the difficulty in doing so, 1500-1700Lbs of trailer, downhill over mixed sand and leaf litter, in another thread. I welded up the metal pieces, tested them with a big f...g hammer, BFH, and mounted the ball/pipe weldment on a wooden bumper brace I made from 4x4 scraps. Painted it gray, and set it aside. Finally, after a camping trip, BB2014, I swung the trailer around on the crest of my driveway's hill, and coupled it to the truck using the pushbar ( two eyebolts hook to the bumper hooks, two straps hold it upright, in the proper location). Worked perfectly, to my wife's surprise (she expected the trailer to break loose, and crash into her truck, located 15" to the right of the trailer's path).
- welding experiment
- 20140111_185722a[1].jpg (97.84 KiB) Viewed 2142 times
- ready to use
- 20140427_143338.jpg (71.67 KiB) Viewed 2142 times
- as used (photo minus top strap)
- 20140426_154745 - Copy.jpg (116.36 KiB) Viewed 2142 times
Eventually, I'll either get a real pushbar (store-bought), or I will get better at welding, and make one from better materials, at home. Either way, for the present-time , I have a purpose-built device that works, cost zilch, and kept me from breaking my back pushing/pulling the trailer. I'll not use it for any other purpose than to push the trailer the last 30 feet down into the garage bay; it's not sturdy enough, nor meant to pull it uphill. Another triumph for Redneck/Southern/(insert derogatory phrase here) Engineering!
