mgraves wide body Benroy
Postby mgraves » Sat Apr 29, 2017 5:51 pm
building fixed place wire looms in the ceiling and front
building fixed wire looms today
mgraves
Images: 127
Re: mgraves wide body Benroy
Postby lacustom » Sat Apr 29, 2017 6:38 pm
What is the width and length ?
Lou Piscitelli
If you can dream it ,we can build it!
lacustom
Postby mgraves » Sat Apr 29, 2017 7:22 pm
Lou, the platform is 79" wide and 10' long. With the Jeep tires it straddles DOT's 8.5' max width. The tongue is extra long to accomodate an aluminum cargo box. You can see the other pics by clicking mgraves. i havent figured out how to add my pic from personal photos to the journal.
mgraves
Images: 127
Postby lacustom » Sat Apr 29, 2017 8:20 pm
I built a 6x12. I put it on a HF trailer. I'm very happy with the size. It's comfortable inside
Lou Piscitelli
lacustom
Postby mgraves » Wed May 03, 2017 7:02 pm
buttoning up the wiring.
mgraves
Images: 127
Postby mgraves » Wed May 03, 2017 7:19 pm
Front drivers corner where shore power comes in and a waterproof receptacle will be as well as a pass thru for trailer lights and 12 volt system starting at the battery in the front utility box.
mgraves
Images: 127
Postby mgraves » Wed May 03, 2017 7:22 pm
mgraves
Images: 127
Postby mgraves » Wed May 03, 2017 7:28 pm
Installing three galley lights with switches incorporated. Two LED yellows, one LED white.
mgraves
Images: 127
Postby mgraves » Wed May 03, 2017 7:33 pm
Mess of wiring will be run along the very top, snaked across the roof or to the rear galley or galley lid for trailer lights and galley lights. Interior walls will be screwed in the make it easily assessible
mgraves
Images: 127
Postby mgraves » Wed May 03, 2017 7:39 pm
mgraves
Images: 127
Postby mgraves » Sun May 14, 2017 8:34 pm
galley counter over head LEDs installed and wires pulled forward to control system
mgraves
Images: 127
Postby mgraves » Sun May 14, 2017 8:40 pm
GFI circuits instaled for refrigerator, microwave and TV and all wiring routed forward to control center.
mgraves
Images: 127
Postby mgraves » Sun May 14, 2017 8:45 pm
octopus of 120 volt that will be behind refrigerator.
mgraves
Images: 127
Postby mgraves » Sun May 21, 2017 9:12 pm
mgraves
Images: 127
Postby mgraves » Sun May 21, 2017 9:16 pm
all 12 volt, 120 volt and trailer running wiresare now forward, ready to be connected to the control center by a real electrician.
mgraves
Images: 127
