Carpet on the walls.......
Postby pk4013 » Sun Apr 30, 2017 1:32 pm
Those of you that have put carpet on the walls in your conversions......can you tell me what your using to apply it. Thanks
pk4013
Re: Carpet on the walls.......
Postby jwhite » Sun Apr 30, 2017 2:39 pm
I used contact cement apply to the wall and the back of the carpet, worked my way up from the bottom to the top. I love the look and feel of carpet would do the same thing again.66566
jwhite
Images: 46
Postby MtnDon » Sun Apr 30, 2017 2:41 pm
3M 30NF Fastbond contact adhesive on the wall and ceiling surfaces. It is non flammable and has less toxic fumes to the user. It can be brushed or rolled on; I rolled most of it, using a brush only in hard to get at corners. It tends to soak into cloth a lot though so I used the 3M spray can on the material backing. I used what is known as hull-liner, not regular carpet. Hull-liner is like an indoor / outdoor carpet but does not have the rubber backing like carpet.
The 30NF is much nicer to use inside confined spaces. The solvents in the standard contact cements are too dangerous for my liking. I sprayed the material in the garage, on the floor over cardboard, with doors open.
MtnDon
Images: 24
Postby pk4013 » Sun Apr 30, 2017 3:40 pm
Thank you for the info....much appreciated!
pk4013
Postby greygoos » Sun Apr 30, 2017 8:02 pm
Indoor Outdoor Carpet Adhesive
greygoos
Postby facethewolf » Mon May 01, 2017 3:01 pm
I've always thought it POSSIBLE to bring an actual couch on a camping trip. But that's the first I've seen it. I think Everyone's entitled to some piece of luxury. Would that one be yours
Sent from my SM-G920F using Tapatalk
facethewolf
Postby EZDog » Mon May 01, 2017 5:31 pm
I just hung the carpet on the plywood walls with a few screws and it works fine and can be removed in about 5 minutes too.
EZDog
Postby videographer » Wed May 03, 2017 7:25 am
I just used self-stick squares. We'll see how well it lasts over the long haul.
videographer
Images: 77
Postby pk4013 » Wed May 03, 2017 2:22 pm
:) Thanks for the info!
pk4013
Postby PaulzOx » Thu May 04, 2017 7:03 am
3M spray contact glue. Has held up well.
Sent from my KFGIWI using Tapatalk
PaulzOx
Postby hankaye » Thu May 04, 2017 8:40 am
Howdy All;
Just one question for all you carpet on the walls folks.
Who's gonna vacuum the walls to keep them clean?
hank
hankaye
Postby EZDog » Thu May 04, 2017 5:27 pm
hankaye wrote:Howdy All;
hank
Yeah Vacuuming Sucks!
EZDog
Users browsing this forum: Google [Bot] and 4 guests
