What are you going to use the wire for?
CCA is great for high frequency applications like audio, communications, and data. Not the best for low frequency like low or high voltage power. Aluminum does not conduct power as good as copper so you need a bigger wire size to handle the same current at copper. CCA was used in houses for a few years in the 70's from what I recall, and the power from the pole or underground to your house is most likely aluminum.
Can you use it in your tear? Sure but there are better choices. And I would just stick to your low voltage stuff like the USB plugs, LED lighting. Probably not to a 12v outlet that might have an invert, heater or 12v hair dryer run off it.
This is what I plan to use in my build,
https://www.amazon.com/Ancor-MArine-Grade-Duplex-Wire/dp/B000NUYAQM?th=1 18GA for all LED, USB, and trailer lights. Then some short runs of 14GA for 120v and a 12v outlet.
![Image](https://images-na.ssl-images-amazon.com/images/I/51gazf41DsL._SL1500_.jpg)
My feeling on power in a TD is most people go way overboard on their wiring. Look at your house and what you plug in on a daily basis. Not things like microwaves, refrigerator, sump pump that should have dedicated circuits. Toaster 100-1500 watts, waffle iron 500-1000 watts, coffee maker 800-1400 watts, probably the thing that you plug in with the most draw is a hair dryer at up to 1800 watts. All these run off 14GA wire and a 15 amp breaker. So unless you want to run a coffee maker and hair dryer at the same time you can't at 15 amps, and guess what, you can't at 20 amps either. I see no reason to run 12GA wire in a TD. Even for AC if you are going to go with a regular house window unit they are made for 15 amps because most electric circuits in bedrooms are 14GA wire so 15 amp breaker. For me I doubt I will put 120v in my build, A.because I don't plan to camp where there is electric, B. I like to camp to get a way from noise so a generator isn't going to happen. C. I don't think I want AC, if it's so hot I would need AC it's to hot to camp. (That just my feeling I know some people need it because of humidly and they like hot weather, I live in the desert and have low humidity. It can be 120 degrees here and I can drive 1.5 hours and be in the mountains and have cool nights.) But if I was going to have one of the portable AC units I would just run an extension cord to the power pedestal. Same thing with the galley. Most campsites have the power pedestal in the back of the site on the left side. A 25' 14GA extension cord with 3 outlet end will cover anything I would ever need while camping.
Good luck,
Todd
PS Love your build thread and your determination.
![Applause :applause:](./images/smilies/econ_applause.gif)
