jwh92020 wrote:I just discovered that something in my 12k btu portable unit sounds like metal shredding, so i to replace the unit. I'm going with a window unit this time (I used the portable because I had it and it worked). The trailer is 7 x 14 with a 6'6" ceiling. The is 1.5" of foam board in the ceiling and 1" in the walls. The a/c will be built into the cabinet that the portable was in. The top of it will be 34" above the floor. I know higher is better, but I don't want to rebuild all the cabinets if I don't have to. Is 6000 btu big enough or should I go to 8000? I'm not an a/c guy, but my understanding is that if the unit is too big, it will not cool correctly. I used a 6k unit in an old canned ham that I remodeled and it worked great, so that is the direction I'm leaning. But if 8k would be better, then 8k it is. Any thoughts will be appreciated.
McDave wrote:Hey jwh92020,
Did you ever hear the saying "old wives tale" ? I think you know where I am going...Anyways, I don't think anybody with a Cargo Conversion will EVER have to worry about having too much BTU and any type of short cycling issues. It's just not gonna happen. You may have short cycling and/or humidity issues, but it wont be from having too much available BTU.
Here's a hint, water, ie moisture is the vehicle by which heat is contained and travels, and is removed.
As far as the height of AC mounting, Don is correct, higher is better but it's not hyper critical. PTAC's, like those used in motel rooms are generally mounted just above the floor.
I know you are not gonna want to hear this so I'll preface by saying IMHO, There is a reason that true RV AC units are sized and located where they are. Wanna' take a guess? Somebody did the math, and then the competition did the math, and surprise...RV AC's are still located and sized in the same manner, Who'da thunk it? .....just sayin'...
McDave
