They work picking up digital. I'm pretty sure analog is completely phased out here.
Camp4Life wrote:EDIT: Not sure about south of the border, but in Canada we lost analog channels years ago and it's now all digital channels, which means you need a DVB antenna, that's why I'm asking. Or do you guys still get analog channels in the States?
videographer wrote:Camp4Life wrote:EDIT: Not sure about south of the border, but in Canada we lost analog channels years ago and it's now all digital channels, which means you need a DVB antenna, that's why I'm asking. Or do you guys still get analog channels in the States?
Nope, the last (full-power) analog TV transmitters were shut off in June 2009. Hard to believe it's been 6 1/2 years already. And here's a secret from a guy who works in TV:
THERE ARE NO "DIGITAL" ANTENNAS, no matter what the label says. The carriers are the same, it's only the payload that has changed. However, a lot of stations changed channels, and many VHFs (read: big antennas) moved to UHF (small antennas.) If you need to know what stations you should be receiving in your area, go to Antennaweb.org and use their search function - it's pretty good.
GPW wrote:Good Morning Mr. and Mrs. America , and all the ships at sea!!!
Today is the skin surgery , and hopefully more painting .... No rain predicted ( a miracle) so hoping we can get a lot done ...
Just an observation ... the skin only bubbles up after sitting in the Heat ... at night it tightens up ... weird huh ? Well, the bubbling only seems to be around the bottom seam , it looks like we’ll be able to slide a putty knife under the seam and separate it enough to peel it back a bit and brush some T2 in the offending area, then press it all back down ... That “should” do it ... Schmaybe’ ?
With the T2 attached skin we have no problems ... with the Gripper we have that long bubble (s) ... grrrrrrr!!! Therefore we will not be using the Gripper any more to attach the skin.. ever !!! It is a great primer , but I don’t know if it’s better than other primers that cost a bit less... It was an interesting experiment ... the odd thing is it worked great in some places and not in other areas ... no idea why that happens...
Will take some pics as we proceed .. Foamies' are supposed to be simple to repair and this should be fairly easy ... We’ll see eh ???
GPW wrote:Sure beats climbing up and down a shaky ladder... Now all I need is a Large metal building to make a TD&TTT workshop ...
